2001 Ford ranger 4.0 cranks no start. possible antitheft questions for the community
  • hobbsautomotiverepair
  • hobbsautomotiverepair's Avatar Topic Author
10 months 2 weeks ago #92465 by hobbsautomotiverepair
hello and merry Christmas to everyone!!! i hope all is well, im looking for some pointers and to see if anyone has ever come across anything like this previously.
01 ford ranger "edge" 4.0 v6 automatic. cranks but no start. customer towed car into me with the steering column apart. red flag to me. he said it was simply to bypass the neutral safety swich. so it will crank with the key however you must put it in neutral to do so.
i have spark. fuel pump is priming. customer had previously replaced the fuel filter with an amazon filter and mistakenly put the return and the feed lines on the wrong lines. i fixed that. i am getting fuel pressure however it is low.
the codes im getting are. -b1359- accessory run circuit. 2.)p0500- vehicle speed sensor circuit error.3.)b.)1342- ECU internal error. this is also stored as a continous code in the pcm as a p code. werid thing is is only sometimes. mitchell and identifix tell me that this code means that the pcm requires replafement. and this would almost make sense to me because on the drivers side bank i have good injector pulse. the passenger side is extremely weak. i belive these are bank driven injection fired.  the knock sensor wires were touching up top on the intake where the sensor plugs in. the owner had them taped together howefver they were still able to touch i feel.  the data shows that the vehicle is enabled... and it says passive anti theft "yes" so im just curious if its intentionally shutting that side down or is it in anti theft mode. my launch will not go bpast the ten minutes to access the critical data i neeed. in the [pats syustem
I would appreiate some pointers on this. i just ordered and recieved my low amp probe from hantek to add to mhy launch o2-2 osciliiscope. so if you could help me adjust my measurements for accurate testing accordingly i would greatly appreciate it!
10 months 2 weeks ago - 10 months 2 weeks ago #92467 by Chad
This thing sounds like a mess.
How low?
There's not much you can do for internal ECU errors. Check the module for good powers and grounds. Then, stick a fork in it. It's done.
Can you elaborate on this? What do you mean by "extremely weak" injector pulse? How are you testing?
All of the injectors share a common power feed from the PCM Power Relay.
Check to make sure that you have good, unfaltering battery voltage at the injector connectors, on both banks, while the injectors are firing. If you have a voltage drop on one bank, take a look at S104.
Each injector has its own control driver, internal to the PCM.
I don't think that this is intentional shut down or anti theft. What module is setting the B1342?
Last edit: 10 months 2 weeks ago by Chad.
The following user(s) said Thank You: Noah, hobbsautomotiverepair
10 months 2 weeks ago #92468 by hobbsautomotiverepair
I apologize for some reason Mitchell will print out many different vehicles with the same engine when I go to diagrams. But what I meant was I didn’t have a low amp probe for my oscilloscope so I was using what I could and cranking with a test light on the control side.. with Keyon engine off. I have battery voltage through both sides. With test light connected to power I had bright light on control wire. And power feed the (red). Passenger bank- 1,2,3, are yellow or white feet wires. While cranking the light is extremely dim. I will now use my scope to confirm faulty driver. But confirmed good ground and power feeds the two tests I have left are to disconnect the pcm and test at the pcm. I had thought I could get a sqaure wave or see the ramp from just using a T pin with my scope. After taking some cloassss I think I’m incorrect on this? So what should I hook my channels up to and the 5ref sig are all good as well. A p 1260 is what made me think the pcm is smoked. From what others have said on Identifix the PCM is bad. The customer had plugged in a different ignition switch from a used car which could be a possibility. Or this the pic on top of the intake I’m attaching it is a two wire connector that goes under the intake. Looks like a knock sensor to me. Colora from the harness yellow w red and violet w green. And as a side note yes this is a mess. lol I should be more careful with what I get myself into rather than trying to make the customer happy,
10 months 2 weeks ago #92469 by hobbsautomotiverepair
Also to answer your question the only things my x431 pad 7 is reading are the pcm, restraint control module, and the generic electronic module. All the “b codes are stored in the “gem” p1000 , incomplete readiness of course in the pcm and intermittent p1260. I’m trying to get into the passive system but after the ten minute delay my scan tool says it is unable to access. I even paid for the immodbilizer download from launch as well as the ford o.e. Software
10 months 2 weeks ago #92470 by hobbsautomotiverepair
This is what I meant by “pats” service module saying “yes” this is live data from the pcm. It says the vehicle is enabled however the theft light when it first got here had stayed on during cranking. Now it is going out after 3aeconss like Mitchell repair manual advised.hopefully this helps a bit.
10 months 2 weeks ago #92471 by Noah
I agree with Chad, this doesn't sound like an anti theft or intentional injector shut down to me either.
As you stated, you should be able to verify injector control by back probing the injector control wires and scoping the voltage.
As Chad pointed out, these injectors are individually driven, not bank fired.
You mentioned low fuel pressure, what is the fuel pressure you are measuring? Will the engine run on alternative fuel like carb cleaner?
The following user(s) said Thank You: Chad, hobbsautomotiverepair
10 months 2 weeks ago #92472 by hobbsautomotiverepair
I’m testing in line at the fuel filter. There is no pressure at the rail. I’ve even bought a new gauge and manually depressed the valve and seemed like air. However last night while testing it almost seemed to start and then seemed like it was vapor locking. So now that I have the hantek 650 amp clamp I can measure with my scope on channel 1. Paul had several channels going for references. Maybe you could quickly assist is it ok to back probe injector with a 20:1? And to ground? Of to the feed wire? Thanks so mich’
10 months 2 weeks ago #92473 by Noah
I use a Verus Edge, there is no need to use an attenuator with Snap On scopes, so I can't really speak of how to use it with your scope. If I was scoping for injector control, I would start with a 20v voltage scale, (all though the inductive spike can be upwards of 100v, it is not important at this point to measure the spike, I am just interested in are the injectors firing or are they not), with a 20ms per division time scale and the ground lead of the scope connected to battery negative. If 20ms does not provide a useable waveform, I will adjust more or less time accordingly.
However, the complete lack of fuel pressure must be addressed. If there's no pressure in the rail, injection control is not a factor.
Did you try to start the engine with an alternative fuel source like carb cleaner?
9 months 4 weeks ago #92509 by hobbsautomotiverepair
apologies on my delay... and yes i have and no bueno. Ive got to get this truck out of my shop and its cold in indiana so me being the only one that works moving it in and out is not a viable option, so its taking up a bay and ive been moving arpound it. last night i connected fuel pressure guage up inline and found that i out of no where got 55psi at the outlet of filter. maybe left over fuel in my guage had caused it to be inop im not sure. i used a brand new guage at the fuel rail and i have a steady 45-50psi after reconnecting lines; i start to smell a lot of fuel, so inquisitively i check the intake with my flashlight and see a pooling of fuel... this might explain the vapor locking... i left my guage on overnight, it did leakdown a small amount but i would assume it would be at zero if i had a stuck injector. i wil use your recommendations on my scope settings and see what i come up with this evening. thanks noah!
9 months 3 weeks ago #92530 by hobbsautomotiverepair
Im sincerely sorry for my delayed response, but thank you so very much for your help and support! The fuel pressure is at 45_50 psi, specs on Mitchell calls for 60-65. Recent update.... Ive been stressed out about this call now and I bought the bullet and ordered a pcm for it... Just in case I needed it I would have ready to go. It just came in today. I want to provide myself with logic and reasoning for what exactly is causing this lol. But I think it's extremely valuable for you to know the intak had a literal pool of fuel in it that could be seen by me checking the throttle body and It as u could imagine wreaked of gasoline smell as soon as I check the air filter the pressure was leaking down pretty quickly which is why pressure would look good and then come down but as soon as I hit the key the pressure still is low so I'm thinking stuck open injector however I still don't understand where all this fuel is coming from I mean I mean could somebody try a customer trying to start this thing over and over and over and over and over again really dump that much fuel in there I mean I would have caught that I feel like when it came in or at least it would have maybe sound like a hydrolock I definitely wouldn't have allowed that to happen or wanted that to happen but I figured this was some key information and I wanted to make sure that I updated the form thank you fellas so very much for you guys this help and support hope to hear from you guys and what your opinions are thank you
9 months 3 weeks ago - 9 months 3 weeks ago #92535 by Noah
Thanks for the update! So the truck does indeed have fuel pressure, that's a good thing. Regarding the fuel pooling in the intake, is this a mechanical return type fuel system? If so, I would disconnect the vacuum line to the fuel pressure regulator to see if the internal diaphragm has ruptured allowing fuel to pass into the intake manifold through the vacuum line. I'm pretty sure there is a Scanner Danner case study featuring a Ford van with this issue.
Last edit: 9 months 3 weeks ago by Noah.
9 months 2 weeks ago #92549 by hobbsautomotiverepair
it is "mechanical returnless" but again, psi is low compared to specs.. and of course it leaks down almost immediately. the rail does indeed have a regulator but there was no fuel in any of the vacuum lines. im thinking it definitely is going to be something stupid simple im overlooking for sure... ill do a cylinder leak down test and compression test and let you know what i find. the antitheft and the eeprom codes threw me for a loop from the very beginning. thank you very much
8 months 1 week ago #92733 by hobbsautomotiverepair
My sincere apologies for the long delay. I had to move on from this truck while I completed other jobs in the shop. I wanted to post an update. Now I'm getting different codes... The accessory run circuit came up. And customer brought this in w a bad battery so I'll order a fresh battery today to eliminate the necessities to have a charger attachment constantly. I'll go ahead and order the ignition switch for it because I had a feeling it felt rough to me while turning. The keys rounded off. It has 200k on the dash. I also confirmed powers and grounds. I'll add a 3 channel screenshot of engine cranking
