2019 jeep renegade was in crash fans not working
  • AdherentSheep19
  • AdherentSheep19's Avatar Topic Author
5 months 3 weeks ago #92940 by AdherentSheep19
2019 jeep renegade was in crash fans not working was created by AdherentSheep19
i am working on a jeep renegade and need help 2.4 engine ac blowing warm 1234yf was in crash fans can be bidirectionaly controlled high and low but they do not come on with the ac and i believe that is why it isnt geting cold it has a charge the fan and condenser was replaced at body shop the compressor cluch works and sol comanding 90 percent but what controls the fans from coming on with ac the fan works but is not coming on why is it not comanding
5 months 3 weeks ago #92944 by Noah
The first thing I would check is if there are there any trouble codes set in any of the modules.
I would also monitor the pressure in the system with gauges and scan data, and check the commanded state of the compressor and fans with the scan tool.
The following user(s) said Thank You: AdherentSheep19
5 months 3 weeks ago #92945 by Tyler
I'd be looking at the A/C high side pressure sensor in the ECM scan data. It's the primary input the ECM is looking at for fan control during A/C operation. You can also monitor evaporator temperature to see if the evaporator is saturating.
Like Noah said, compare the A/C high side pressure sensor against the gauges, if you have them available.
  • AdherentSheep19
5 months 3 weeks ago #92946 by AdherentSheep19
Replied by AdherentSheep19 on topic 2019 jeep renegade was in crash fans not working
so the compressor isnt workin enough to turn the fans on bc i have no codes its a compressor with one of the variable sol and a compressor clutch the pressure only gets to 150 psi
  • AdherentSheep19
5 months 3 weeks ago #92947 by AdherentSheep19
the compressor is on but im not really sure the logic on the fan the fan should be on with compressor the pressures are 150 high side the car only has 32k maybe when it got in a accident the body shop not charging the ac or it took a dump? id hate to just throw a compressor on it but im thinking of putting a used compressor on it
5 months 3 weeks ago #92948 by Tyler
150 PSI is probably not enough for the ECM to turn the fans on. Most domestic makes will wait until the pressure exceeds 250 PSI, in my experience.
Was your reading of 150 PSI with a gauge at the high side port, or on scan data? Is the high side port on the discharge line or the liquid line?
The body shop recharged the A/C system? The charge may be low, but there's still a couple more tests you can do before shipping it back to them.
  • AdherentSheep19
5 months 3 weeks ago #92949 by AdherentSheep19
the body shop did not charge the sys when they put the condenser on then when i sucked the sys down it said it took ref out but i charged it and got good contact on the pulg to actuate the compressor clutch but i always thought the high side was low but the car was driven around before a recharge and im wondering if it burnt the compressor up
5 months 3 weeks ago #92955 by Noah
Usually driving with the system empty isn't enough to hurt the compressor. Without pressure in the system the compressor shouldn't engage.
  • AdherentSheep19
3 months 2 weeks ago - 3 months 2 weeks ago #93077 by AdherentSheep19
ok update sorry been busy with alot of stuff so i replaced the sol for the comp charged it the jeep blows cold 250 hi 50 low now the problem i am having is i have to comand the fan on through autel to get it to work i havent spent much time on it but the sys should comand the fan with a/c on im just puzzled bc the fan works but not when ac is turned on. could the fans or a module be bad maybe need a flash or update or maybe try powering everything down idk im lost
btw the sol pin was bent so idk if it was from me testing it or from something els crash or body shop
Last edit: 3 months 2 weeks ago by AdherentSheep19.
3 months 1 week ago #93090 by Noah
Does it not cool unless the fans are on? I have seen a few instances where the high side pressure doesn't reach high enough to engage the fans and the tech working on the car assumed the lack of fans was the issue.
2 months 2 weeks ago #93132 by Tutti57
Have you checked scan data pressure like Tyler mentioned? The pressure may be there on the gauges but if the sensor doesn't see it, the fans won't come on. I'd double check the inputs, like ambient temp sensor too, if it was in a front end accident.
Time to create page: 0.358 seconds
