2000 saturn sw2 dohc high negative fuel trims
- cheryl hartkorn
- Thank you received: 130
- cheryl hartkorn
- Paul P.
- Thank you received: 195
You said both O2's were rich, which would make me suspect a high fuel pressure issue, and a very leaky injector. If its a fuel issue, with those neg FT's you should be smelling unburnt fuel at the tailpipe. The Fuel regulator is the fuel filter for this vehicle, FP spec is 40-55 PSI.
A very dirty or poorly performing MAF will cause this as well. What were the g/s at idle?
Because both sensors were rich, I'm leaning toward a fuel issue.
This doesn't sound like a fuel trim relearn. But you could disconnect the bat cable and cross them to drain the ft memory.
Do the IAT and ECT reading seem reasonable?
Never stop Learning.
- cheryl hartkorn
- Paul P.
I see your frustration, a MAP engine!
How do the plugs Look? is it being overfueled? (leaky injector at this point)
Do those trims improve at higher rpm? A wonky egr could cause this too.
- cheryl hartkorn
- Paul P.
The vehicle is in closed loop I take it? How does it sound on cold startup...smooth or sluggish? I concur about the egr valves. Starting to wonder if you're dealing with a false rich condition.
May I ask if you have any evidence to support a pcm?
- Paul P.
Cheryl, are you able to pinch off the return line? if so, what happens?
- cheryl hartkorn
- Paul P.
Awesome job covering the bases. Please post your findings.
- cheryl hartkorn
- nathan.carpenter
- Thank you received: 3
Sent from my SM-G965U using Tapatalk
- kostelectronics
- Thank you received: 7
...Sorry if i'm wrong, but it was my first thought after reading all this.
- cheryl hartkorn
- Rev Scott
- Thank you received: 10
Kinda like how Hondas do, where the exhaust valve lash tightens up so bad they will run rich?
You could do a cylinder leak down test and wrap a rubber glove around the tailpipe to help identify a small leak.
