2002 Dodge 1500 quad cab 4.7L gas 2X4
  • Adrenaline Motorsports
  • Adrenaline Motorsports's Avatar Topic Author
7 years 9 months ago - 7 years 9 months ago #26683 by Adrenaline Motorsports
2002 Dodge 1500 quad cab 4.7L gas 2X4 was created by Adrenaline Motorsports
P0202 Hard code. Noid light flashes with the same consistentsy and brightness on all injector plug connections. Road test trouble code results: P0300, P0301, P0302 and P0304. Could the Ignition Capacitor/Resistor be responsible for P0202 hard code and subsuquential random misfire codes? Injector #2 Signal circuit from the computer is closed. Capacitor/Resistor part #56028644AA
Last edit: 7 years 9 months ago by Adrenaline Motorsports. Reason: Added engine size
7 years 9 months ago #26690 by Tyler
Replied by Tyler on topic 2002 Dodge 1500 quad cab 4.7L gas 2X4
I very much doubt that the ignition capacitor is inadvertently causing the P0202, but I've been wrong before! :silly: From what I know about CDJR injector monitoring, the PCM is looking for the inductive kick at the end of the injector voltage waveform to determine if work actually took place. If the kick is weak or non-existent, you get this code.
How does the resistance of the #2 injector compare to others? I don't know the spec off hand, but I'd say a difference of more than two ohms is a red flag. You could also scope the control side, or take a current measurement, and compare.
Time to create page: 0.239 seconds
