01 dodge grand caravan abs
7 years 9 months ago #26803 by Force
01 dodge grand caravan abs was created by Force
Have an 01 caravan that has unwanted abs engagement....around 10 mph or so if you lightly apply brakes the abs kicks in....looking at wheel sensors on scanner they all read same mph and none drop out...no codes set...there is a reference voltage tha bounces from 4.1 to 9.9 volts
  • chief eaglebear
  • chief eaglebear's Avatar
7 years 9 months ago #26806 by chief eaglebear
Replied by chief eaglebear on topic 01 dodge grand caravan abs
hi ngk has a good study on something like this it turned out to be high resistance in abs sensor circuit so module was acting up causing low rpm engagement
  • chief eaglebear
7 years 8 months ago #26831 by chief eaglebear
hi sir because of the fluctuating voltage I am suspecting a bad ground at g100 or possible the g200 spot which is the traction control module the speed sensor have two wires which are powered and grounded thru brake control module im still trying to master this stuff so please forgive if I lead you down the wrong path but I guess as SD would say eliminate all the variables
