95 Tahoe 5.7 No spark fuel good
  • Mikemehl010
  • Mikemehl010's Avatar Topic Author
7 years 8 months ago #27001 by Mikemehl010
95 Tahoe 5.7 No spark fuel good was created by Mikemehl010
Good afternoon. Have a 95 Tahoe no spark fuel is good replace the distributor not the problem. Check power at coil good. If I disconnect white wire from computer I do have spark. Thank you
  • chief eaglebear
  • chief eaglebear's Avatar
7 years 8 months ago #27003 by chief eaglebear
Replied by chief eaglebear on topic 95 Tahoe 5.7 No spark fuel good
hi sir there is a tsb on this vehicle for injector pulse width I am still trying to find schematic with cam crank sensor in it for some reason I always have a hard time finding sensors in BBB
  • chief eaglebear
7 years 8 months ago - 7 years 8 months ago #27004 by chief eaglebear
hi sir I find something particular about this tsb within it it menchones hooking up a scan tool I was under the impression all pre obd 2 vehicles did not have a dlc to hook up a scan tool this vehicle might be obd 2 but if not short the pins in dlc to pull codes
Last edit: 7 years 8 months ago by chief eaglebear.
  • chief eaglebear
7 years 8 months ago - 7 years 8 months ago #27006 by chief eaglebear
7 years 8 months ago #27036 by Rev Scott
Replied by Rev Scott on topic 95 Tahoe 5.7 No spark fuel good
chief eaglebear wrote: hi sir I find something particular about this tsb within it it menchones hooking up a scan tool I was under the impression all pre obd 2 vehicles did not have a dlc to hook up a scan tool this vehicle might be obd 2 but if not short the pins in dlc to pull codes
There are dozens of pre-95 car lines that are scan tool capable. Chevy has OBD1, which has a 12 pin DLC connector A scan tool can be used just fine if you have the adapter (my Verus has it), and there is quite a bit of data available.
  • chief eaglebear
7 years 8 months ago #27041 by chief eaglebear
ah yes forgot about the 12 pin dlc
