Holden Epica/Daewoo Tosca steering angle sensor issue
  • Paul6004
  • Paul6004's Avatar Topic Author
7 years 8 months ago - 7 years 8 months ago #27009 by Paul6004
9 Months ago this came in with a fault for the steering angle sensor - code C0460-4B. It has returned with the same fault. It is a 2011 Holden Epica (re-badged Daewoo Tosca). I can't seem to re-calibrate it and called the dealers who advised getting another new sensor under warranty before replacing the ABS module. We did that with no change. I ordered a good(?) used ABS pump and fitted that and immediately got C0460, C0131 "pressure sensor" and C0186 "lateral sensor". All the codes cleared except C0460 "SAS not calibrated'. I tried with several scan tools to calibrate it. Finally the old Launch X431 said it was successful but the code showed again.
I connected the oscilloscope to the sensor wiring - it has 6 wires. Ground, Positive 2 X CAN hi and 2 X CAN lo. The wiring diagram shows that it shares CAN wiring with the lateral sensor.
The poitive and ground are good - when I clear the code the positive falls away for a second - maybe that's normal but it doesn't fall away with the engine running. The CAN wiring seems to have some spikes on it - I'm not sure though whether that is a problem or not? Interested in suggestions.
Last edit: 7 years 8 months ago by Paul6004.
  • Paul6004
7 years 8 months ago #27012 by Paul6004
The Autoland scanner gets in and says it is doing a calibration then says "Link failure". The Autel maxisys doesn't even have an option for calibration. I've put the vehicle on stands so I can turn the steering easily, every now and then I turn it full lock in either direction to see if it will do a re-learn. I connected my Foxwell and it has the relearn function but doesn't succeed.
  • chief eaglebear
  • chief eaglebear's Avatar
7 years 8 months ago #27018 by chief eaglebear
Replied by chief eaglebear on topic Holden Epica/Daewoo Tosca steering angle sensor issue
im looking at this wondering why steering angle sensor needs to communicate with EBCM and the whole yaw rate sensor there something going on here
  • Paul6004
7 years 8 months ago #27020 by Paul6004
When I took it for a drive yesterday the airbag light came on as well and someone mentioned to me that the airbag module and
YAW rate sensor are mounted close to each other in the centre console - could be "coffee contamination" perhaps? :)
I may get some time to get back onto it today.
  • chief eaglebear
7 years 8 months ago #27023 by chief eaglebear
Maybe check can bus comms while rotating steering wheel also there is something about yaw rate sensor itshould have a speed signal input somewhere (just a thought)
  • chief eaglebear
7 years 8 months ago #27024 by chief eaglebear
Yah know theore I look at this I would say it is some kind of comm problem the yaw rate sensor relies on different signals the ebcm and steering angle sensor rely on inputs apart from powers and grounds I would verify topology and make sure everything is communicating and also I am not actually an auto tech yet. But i did sleep at a Holiday inn last night lol
7 years 8 months ago #27025 by mcmullan
live data- check wheel speed sensors and also SAS value, does it read and register a change in degree? SRS monitors yaw as 1 of its inputs, are there any faults stored in SRS? As you know some cars you will do SAS calibration and then once initiated have to drive in a straight line. Not 100% on this model, also as I mentioned WSS can be important here again model specific but worth bearing in mind.
  • chief eaglebear
7 years 8 months ago #27026 by chief eaglebear
Hi do you mean the supplemental restraint system monitors Inputs or what is srs ?
  • chief eaglebear
7 years 8 months ago #27046 by chief eaglebear
can signals look ok to me with just a lot of noise for some reason can we do a resistance test on can bus system to check that
  • Paul6004
7 years 8 months ago #27050 by Paul6004
chief eaglebear wrote: Hi do you mean the supplemental restraint system monitors Inputs or what is srs ?
Yep, I meant the airbag module - just that they are mounted near each other so if someone spilled something in the centre console they might both be affected. It is pretty messy in the car - but the YAW sensor looked clean.
7 years 8 months ago - 7 years 8 months ago #27361 by Desmond6004
The airbag fault is due to a passenger detection fault.
Otherwise - we took the vehicle to the dealership for their 'superior' diagnostic tools as advised by the supplier of the used parts. After 2 days they called and told us it needs a $2000 ABS module. After we told them we had already replaced the module and it would be very rare for them to have the same fault they went back to it to see if they could reprogram it. They failed at that and we have the vehicle back again. Our supplier sent another used ABS module plus a YAW rate sensor which I have fitted. I plugged in the 'new' ABS module and it gives exactly the same fault code. I'm about to scope the CANBUS signal from the steering sensor to the YAW rate sensor and see if there are any clues there.
Last edit: 7 years 8 months ago by Desmond6004.
7 years 8 months ago #27362 by Desmond6004
This is the pattern at the YAW rate sensor. Something not quite right there but we have another ABS module, steering angle sensor and YAW rate sensor.
7 years 8 months ago #27364 by Desmond6004
With the YAW rate sensor unplugged I don't get the hash. Ground and positive at the sensor are good. It is another sensor supplied by the
company that supplied the used ABS module as well.
7 years 8 months ago #27366 by Desmond6004
I just tried running new CAN wires to the YAW sensor - no change.
Time to create page: 0.370 seconds
