2005 Chrysler Town & Country 3.8 P0406 EGR sensor high- follow up
- Mechanic 350
- Thank you received: 15
7 years 8 months ago #27301
by Mechanic 350
2005 Chrysler Town & Country 3.8 P0406 EGR sensor high- follow up was created by Mechanic 350
So here is the latest with this vehicle.
unplugged solenoid
tested ground circuit is good = 0v
tested control wire circuit = wire has 9.39v on it. this wire according to how paul taught me in the book is not suppose to carry any voltage at all.
Does that mean that this wire is shorted to b+ somewhere in the harness? I'm stuck up to this point. thanks
unplugged solenoid
- Mechanic 350
7 years 8 months ago #27302
by Mechanic 350
Replied by Mechanic 350 on topic 2005 Chrysler Town & Country 3.8 P0406 EGR sensor high- follow up
another issue that i noticed is this. Since this is a chrysler product, with the solenoid unplugged, that voltage that i'm seeing, in the control wire, is that my bias voltage?
7 years 8 months ago #27303
Connect an incandescent test light to battery negative and ,while reading the 9.39 volts with a volt meter, touch the test light to the control wire. Does the voltage disappear? Or, does your test light, dimmly, light up? If it disappears, I would say it is a bias voltage. If it lights the test light, I would say short to power.
Replied by Chad on topic 2005 Chrysler Town & Country 3.8 P0406 EGR sensor high- follow up
MOROSO321 wrote: another issue that i noticed is this. Since this is a chrysler product, with the solenoid unplugged, that voltage that i'm seeing, in the control wire, is that my bias voltage?
- Mechanic 350
7 years 8 months ago #27304
by Mechanic 350
Ok pole71, I’ll try that test. Thanks. I’ll get back to you.
