Crank no start
- ruben
7 years 7 months ago #27928
by ruben
Crank no start was created by ruben
1998 Nissan Altima 2.4 l Automatic. Died suddenly checked it and it has no spark. I have a code PO340 camshaft position sensor malfunction circuit A. Since the cam sensor is built in to the distributor I figured that's what it is since I have no means of getting a wiring diagram or none that I found on the internet at least. Installed it but same symptoms still get the code for the cam sensor. Checked fuses and relays they all check out ok. What am I missing please help.
- cheryl hartkorn
- Thank you received: 130
7 years 7 months ago #27935
by cheryl hartkorn
Replied by cheryl hartkorn on topic Crank no start
is the distributor rotorturning when cranking the engine??
- ruben
7 years 7 months ago #27937
by ruben
Replied by ruben on topic Crank no start
Yes it is turning. New distributor, timing chain is strong as well. I'm going to take the distributor apart maybe something not connected. Still unsure.
7 years 7 months ago #27938
Replied by Andy.MacFadyen on topic Crank no start
Istr Paul did a video on this issue, not at home right now but will try to find it.
- ruben
7 years 7 months ago #27939
by ruben
Any help appreciated. Thank you.
7 years 7 months ago #27941
I can't find a Nissan video but there are others on similar Honda and Toyota setups.
This type of arrangement with a horizontal electronic distributor are prone to failure due engine oil leaking into the distributor body as the engine ages.
If there is oil leaking into the distributor body make 100% the crankcase ventilation system is clear before fitting new parts.
It also goes without say to check powers and grounds to the distributor first.
- ScannerDanner
- Administrator
- Thank you received: 500
7 years 7 months ago #27947
by ScannerDanner
Don't be a parts changer!
Replied by ScannerDanner on topic Crank no start
@Andy Macfadyen that was a premium video my friend. Let me see what I can find.
- ScannerDanner
- Administrator
7 years 7 months ago - 7 years 7 months ago #27948
by ScannerDanner
This is a V-6 Nissan Distributor engine but the tests I show on the distributor signals would be identical.
This is a premium video that I had locked down (private) on YouTube but I made it unlisted so you can watch it without having to subscribe to ScannerDanner Premium.
Will you please let me know when you are done watching this video so I can lock it up again?
Thanks!
Thanks!
Last edit: 7 years 7 months ago by ScannerDanner.
The following user(s) said Thank You: chief eaglebear, Columbus450
- ruben
7 years 7 months ago #27949
by ruben
Thank you for the video. I'm gonna take the distributor apart when I get home. Being new and all I trust it should be good but then again something could be wrong with it internally.
