2002 toyota highlander driver's power window fuse keeps blown
  • Baraka
  • Baraka's Avatar Topic Author
7 years 7 months ago #27987 by Baraka
I have a case study, actually I wasn't the one working on this repair from the start, so I did a close inspection I found out there was no (D FR DOOR FUSE) so I looked for a spare fuse and placed it in, it got blown instantly.. I need help on getting the complete power window fuse diagram...
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
7 years 7 months ago #27996 by Dylan
Moving your thread to the repair section ;)
7 years 7 months ago #28023 by Andy.MacFadyen
Issues like this are often inside the door panel, I would pull the trim panel off the door and look for damage wiring anywhere there is movement or sharp edges, if you can't see any pull the kick panel off and do the same. I f nothing apparent disconnect the motor inside the door an try replacing the fuse.
