Possible bad ECU
- rudolph.palm
- Dont Limit Your Challenges, Challenge your Limits!
- Thank you received: 3
- rudolph.palm
- McFly1
rudolph.palm wrote: Hi, everybody, the hard reset did not change the situation. One detail I noticed lately. When the engine just starts, it starts with some slightly misfire feeling which can better be observed standing behind the car and listening to the exhaust pipe. The typical misfiring sound is there even after initial start up, but it can barely be sensed siting in the car. So there is always some misfiring but it got worse after 20 to 25 seconds when the P0350 appears and the number one injection has been shut down. There is for sure something wrong in the ignition system seeing the persistence appearing of the P0350.
Yeah, that's what's been beating me up the whole time. :silly: I'm sure the P0350 is related, but I can't find any info on it. Do you have another scanner available? Maybe try it to make sure you're not getting lied to.
- rudolph.palm
- rudolph.palm
- Dtnel
- Thank you received: 67
Also I was wondering udba reflashing of the ECM would make a difference and I'm sure one of scannerdanner's number 11rules of check the TSB's is out the door being the market you said the engine was for unless they're vigilant about TSB's over there. Where is this car by chance anyways.
I would recommend getting ahold of Jorge over at AESwave.com and seeing if he has any used trades, demo's or other type of Picoscope's whether 2 or 4 channel that may be able to fit in a budget range. They do great things at AESwave . Explain your situation to him as these guys are on the front lines at times doing training of people in various shows, tech training seminars around the country throughout the year.
Also you could check the boards over at Autonerdz.com and see if anyone has any information over there.
There's also a few other boards that I can't think of at the time but some are related to shops in the industry so they're may be some fees there.
Maybe I missed it but what happened when you switched the coil / coilpack for that cylinder?
What's your location if you don't mind me asking?
Sent from my SM-N960U using Tapatalk
- rudolph.palm
My location is Curacao, Island in the Caribbean. I am a follower of ScannerDanner videos and I appreciate all the valuables advices and/or comments from you guys on this forum. I am not done with this car, I never felt comfortable watching an unfixed car exiting my shop!. But for all the troubleshooting performed, I believe it will be worth to put at least a used ECU in this car to see what happens. I will check the boards you suggested, thanks for those! Any further development will be posted on this forum so you guys can follow! Thanks Again!
I've never used the Autel scope? Always heard that the software was tough to work with when it first came out, but has since been updated and vastly improved. Do you already own an Autel?
Tough to go wrong with a Pico.
