FIXED 2007 subara legacy 2.5 liter non turbo p1443
- cheryl hartkorn
- Thank you received: 130
Vehicle » Powertrain Management » Emission Control Systems » Description and Operation » Evaporative Emission Control System » Vent Valve
VENT VALVE
VENT VALVE
The vent valve is incorporated in the fuel tank. During filling the fuel tank, fuel vapors are introduced into the canister through the vent valve.
When the fuel vapor pressure becomes higher than the atmospheric pressure and overcomes the spring force which is applied to the back side of the diaphragm, the port toward the canister is opened. The vent valve also has a float which rises and block the port toward the canister when the fuel is full.
PRESSURE CONTROL SOLENOID VALVE
Zoom Sized for Print
The fuel tank pressure control solenoid valve is located in the evaporation line between the canister and the fuel tank.
When the tank inside pressure becomes higher than the atmospheric pressure, the valve is opened allowing fuel vapors to be introduced into the canister.
On the other hand, when the tank inside pressure becomes lower than the atmospheric pressure, external air is taken from the drain valve into the canister.
- cheryl hartkorn
- cheryl hartkorn
Thanks!pole71 wrote: Vent Control schematic
So, while the code definition is: VENT CONTROL SOLENOID VALVE FUNCTION PROBLEM, the associated diagram and troubleshooting info refers to the drain valve, as pictured in the diagram pole71 posted.
It says to check for other codes, check the drain hose for a blockage and then check the functionality of the drain valve
Do you have any bidirectional control of this solenoid with your scanner?
- cheryl hartkorn
- cheryl hartkorn
- cheryl hartkorn
I forgot about that Subaru diagnostic output connector, I like that feature. Honestly, I like a lot of the stuff Subaru does.
So, excuse me if I missed it, but you found no control to valve, even at the PCM. Replaced the PCM, and it still doesn't have control?
- cheryl hartkorn
