2005 TOYOTA COROLLA XRS
- tiffanie.kimberlin
7 years 6 months ago #28968
by tiffanie.kimberlin
2005 TOYOTA COROLLA XRS was created by tiffanie.kimberlin
toyota corolla 2005 XRS Using a test light , No pulse on the injectors On the battery feed, it lights up. Where is the problem of not getting a pulse. it cranks but wont start
- chief eaglebear
- Thank you received: 70
7 years 6 months ago - 7 years 6 months ago #28969
by chief eaglebear
Replied by chief eaglebear on topic 2005 TOYOTA COROLLA XRS
when turning power on do you get a speedometer bump or can you hear pump prime
Last edit: 7 years 6 months ago by chief eaglebear.
- chief eaglebear
7 years 6 months ago #28970
by chief eaglebear
if speedometer needle does not move at all or when turning power on and you cant hear the pump prime you may have lost a crank or cam signal which is a critical input there are other factors too like weak battery so turn on lights and check that they are bright and not dimmed
7 years 6 months ago #28972
Replied by tiffanie.kimberlin on topic 2005 TOYOTA COROLLA XRS
YES EVERYTHING TURNS ON LIKE IT SHOULD AND WE HAVE FUEL PRESSURE AT THE CORRECT PRESSURE. AUDIBLY HEAR THE PUMP. ALL FUSES AND RELAYS ARE GOOD. JUST NO FUEL AT THE INJECTORS. IT IS LIKE SOMETHING IS TELLING IT NOT TO TRIGGER THE INJECTORS. IS THERE A SAFETY FUEL SHUT OFF SWITCH?
- cheryl hartkorn
- Thank you received: 130
7 years 6 months ago #28973
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2005 TOYOTA COROLLA XRS
try another key?? could be security shutting it down
7 years 6 months ago #28974
TRIED ALL KEYS AND HAD SECURITY RESET
- chief eaglebear
7 years 6 months ago #28993
by chief eaglebear
hi its hard to find right diagrams on BBB but there are three IGF lines and two IGT lines coming from ecu for ignitor and ignition feed I try helping from my lunch break I work in a warehouse but my heart is in a shop I wish I could get right diagrams on BBB I do not have access to things like alldata or Mitchell but I believe that vehicle does have ignitor circuit I would start there with no spark scanner danner has some good vids on ignitor circuits good luck
