2009 Cobalt 2.2 Ecotech Crank No start
- erieadams
Replaced Timing chain. Original Key broke off inside ignition so replaced the complete Ignition not just tumbler and programmed new key.
Still have a crank no start tested all relays and fuses have spark have fuel spark does seem weak but main issue I am having trouble with is with my scan tool hooked up to read codes but when I go to live data if i crank the engine i lose power to obd2 port and have to release the key back to on position to reconnect I have checked all relays fuses inside and out and also grounds on engine all seem tight and not broken what can cause a obd2 port to lose power only when cranking engine also tach does not move during cranking so main reason wanting to view live data is to see if rpm is moving any suggestions
ALSO lose power to cig lighter during cranking as well so am I missing looking for bad ground someplace ?
- erieadams
- erieadams
- erieadams
- guafa
- Thank you received: 80
I have a similar issue with a chevy HHR (pretty the same circuit). If your car has battery in the trunk, look for main power cable which comes from battery (+) to hood fuse box or the one which comes from battery (-) to body chasis.
I had to add a #4 cable from battery (-) to block in order to improve ground and decrease electronic noises.
Also main power cable was completely corroded and broken.
- guafa
Voltage should be the same.
You can discard my theory quickly, by adding a second battery connected in parallel like this:
Battery (-) to block and battery (+) to hood fuse box voltage input.
Also, with the Negative Lead of your DVOM connected to Battery (-), touch the Red Lead to the Engine block while you are cranking. What voltage do you read? Touch the Red Lead to the Body, while cranking. What voltage to you read?
- erieadams
where exactly would that splice be you circled
You'll have to follow the cable from the batter (+). I assume it will be very close to, or at, the fuse box. All I can say, for sure, is "Between the fuses and the battery. :huh:
- erieadams
- erieadams
