Oil pressure
  • Carstuff
  • Carstuff's Avatar Topic Author
9 years 11 months ago #3819 by Carstuff
Oil pressure was created by Carstuff
What is the oil pressure range for 2002 freelander . Not the minimum reading but the full range.
9 years 11 months ago - 9 years 11 months ago #3834 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Oil pressure
Which engine? What grade oil is in the sump?
Edit
A quick check reveals Rover petrol & diesel Max 5 bar, oil pressure switch 0.5 to 1 bar. The BMW diesel should be similar.
BMW diesel is prone to the light coming on at idle which can be due to a dirty MAF pulling the idle speed down and the oil pressure switch going out of calibration with age.
There have been reports of the oil pressure switch wiring on a few very high mileage KV6 engines in Rover cars,
Original oil spec is part or fully synthetic 5w/40 or 10w/40 for temperate climates but the Rover K engines are quite happy on 5w/30.
Last edit: 9 years 11 months ago by Andy.MacFadyen.
  • Carstuff
9 years 11 months ago #3837 by Carstuff
Replied by Carstuff on topic Oil pressure
2.5 10w40
  • Carstuff
9 years 11 months ago #3838 by Carstuff
Gas model
9 years 11 months ago #3840 by Andy.MacFadyen
Pressure switch problems aren't unknown also check the wiring and check for oil dilution.
3 bar at 2,500 rpm when fully warm is the value given for this engine in a car, 2.5 bar wouldn't worry.
  • Carstuff
9 years 11 months ago #3841 by Carstuff
At idle after highway run im showing 0.8 bars on idle and 3000rpm is 2.1 bars
9 years 11 months ago #3844 by Andy.MacFadyen
I wouldn't worry to much with that however if the oil light is blinking at idle try a pressure switch. I am not sure if the pressure relief valve can be removed cleaning or replacememt.
These engines aren't prone to bearing problems, one possibility is the oil pick-up tube in the sump is either drawing air at its' o ring seal or its' mesh filter is gummed up.
The oil pump is on the front of the crankshaft, not an expensive part but it means dealing with the timing belt, if the 1.8 in line 4 or the 2 litre v6 you can get away without special tools but the tools are a must have for the 2.5 v6 as this has an unusually complex VVC.
  • Carstuff
9 years 11 months ago #3845 by Carstuff
The light flickers when pressure is near 7psi sometimes it dips near 7psi but mostly it's at 10psi at idle . Stable needle it seems to be below the pressure specs you provided.
9 years 11 months ago #3846 by Andy.MacFadyen
Try some 15w/40 or 15w/50 in it
  • Carstuff
9 years 11 months ago #3847 by Carstuff
It's odd that now it requires thicker oil. Something must of happen.
9 years 11 months ago #3848 by Andy.MacFadyen
Gradual wear --- however keep in mind if engine has a lot of sludge (which is unusual in these engines) it could could be sludge on the inlet to the pump restricting oil flow.
  • Carstuff
9 years 11 months ago #3849 by Carstuff
I guess the pump should be ok. Haven't seen any sludge at oil change.
9 years 11 months ago #3871 by Andy.MacFadyen
It looks like the oil pressure switch out of spec
  • Carstuff
9 years 11 months ago #3873 by Carstuff
I had a mechanical gauge installed and it shows it at 10 psi at idle close to the warning psi when it flickers.
  • Carstuff
9 years 10 months ago #4014 by Carstuff
I dropped the pan and the screen was almost clogged . There was some gunk in there. Cleaned the pan and screen and the pressure hasn't improved. Same 10.2psi on guage.
9 years 10 months ago #4022 by Andy.MacFadyen
The switch specification is 3.5 to 6.5 PSI ---- new switch required
  • Carstuff
9 years 10 months ago #4023 by Carstuff
I will look into that. However when the light flicked it was at mechanical guage warning range and you could heard very light tapping. Pressure is higher but still low at 10psi if I shut it off for a few minutes and restart.
9 years 10 months ago #4032 by Andy.MacFadyen
The light tapping noise is more likely to be from the top end of the a big end bearing problem tens to be a fairly solid knocking sound that appears as you raise the RPM towards 2,000 or so. I have encountered a couple of sticking hydraulic tappets on the 4 cylinder version of the engine.
There is a tendancy to put too much importance on oil pressure, the oil pump pressure dosen't force the bearing shell surface clear of the crank journal the bearing just needs a steady flow of oil as the bearing actually act as pump and draws oil in. The oil pressure that keeps the bearing shell clear of the crank journal surface is generated within the bearing.
  • Carstuff
9 years 10 months ago #4054 by Carstuff
Looks like the bearing is worn I will have to pull them out. But this model can't be down from oil pan it. Do you know about matching the color coded bearings because they fade off from old bearing.
9 years 10 months ago #4087 by Andy.MacFadyen
I don't think the bearing wear is at the problem stage yet.
10psi is well above the the pressure the oil pressure switch should work.
Rover listed a repair kit for the oil pump on the 1.8 version in line 4 that included a replacement spring for the oil pressure relief valve, although the design is not dissimilar on the V6 they don't list a kit for that engine.
I suspect relief valve openning at too low a pressure may be the main reason for your slightly low oil pressure at higher cruising RPM when warm
Time to create page: 0.354 seconds
