Mercedes Benz C Class C240
  • Loney911
  • Loney911's Avatar Topic Author
7 years 5 months ago #29528 by Loney911
Mercedes Benz C Class C240 was created by Loney911
Hi
My Benz C-Class C240
Year 2002
Won't Crank and Start so I checked all the fuses and relays no blown fuses and relays
But I found there is no power on fuse #52 (start enable) 20A fuse located under the hood
Please assist me to solve the problem?
What is next step?
Thank you
7 years 5 months ago #29530 by jreardon
Replied by jreardon on topic Mercedes Benz C Class C240
imgur.com/a/IQ7pqUD
In the crank position is Fuse 52 hot?
In the crank position are any of the fuses #48, #47,#49 or #46, hot?
Do your wipers work? (fed from fuse #46)
  • Loney911
7 years 5 months ago #29537 by Loney911
Replied by Loney911 on topic Mercedes Benz C Class C240
jreardon wrote: imgur.com/a/IQ7pqUD
Here is fuses listed
Fuse 52 is Start Enable (no current in positive side pin)
Fuse 48 is Engine Electronics (working have current)
Fuse 47 (working have current)
Fuse 49 (working have current)
Fuse 46 is windscreen wiper it has current but viper is not working
And no fuses are hot
Fuse 58 (transmission electronic) also have no current in positive side pin
*when key is on fan start running
7 years 5 months ago #29539 by jreardon
Forgive my poor choice of the word "hot." I should have wrote, do you have power at both sides of the fuse.
Your result that all those fuses have current (Did you mean power? If you measured current that's fine, you can't have current flow without power) suggests to me that the Circuit Opening Relay has control and the relay is functional.
7 years 5 months ago - 7 years 5 months ago #29540 by jreardon
Can you see if the Circuit Opening Relay can be swapped with the Starter Relay? If so, see if engine cranks.
edit: those relays don't look the same.
Does starter relay have a diagram etched on it?
Last edit: 7 years 5 months ago by jreardon.
  • Loney911
7 years 5 months ago #29541 by Loney911
jreardon wrote: Forgive my poor choice of the word "hot." I should have wrote, do you have power at both sides of the fuse.
Yes I mean power
But Fuse 52 and 58 had no power on any side and all the other fuses have power on both side , All the relays are checked and working
  • Loney911
7 years 5 months ago #29542 by Loney911
Yes i did swapped stater fuse but won’t crank
7 years 5 months ago - 7 years 5 months ago #29544 by jreardon
You swapped the fuse or starter relay? Fuse 52 won't have power on either side because the starter relay coil is not being energized by the SAM module (whatever that is). Either that, or the relay is defective.
Can you feel the starter relay click?
7 years 5 months ago - 7 years 5 months ago #29547 by jreardon
If you pull the starter relay, there are 4 female terminals (?). Two goes to the SAM module so I'm not sure what voltage, if any, to read on those two. The two others , well, one one them should be grounded through starter motor. And the last one should have power when fuses 48, 47, 49 get power.
Can you find a diagram etched on the starter relay to indicate the load side pins?
If you jump the correct (very important or you will fry the SAM module) load side female terminals, the starter should spin.
7 years 5 months ago - 7 years 5 months ago #29548 by jreardon
Is this what starter relay looks like?
  • Loney911
7 years 5 months ago #29549 by Loney911
No click sound from Starter relay and it’s not energized
starter relay positive terminal has no power
But ground terminal is ok
7 years 5 months ago - 7 years 5 months ago #29551 by jreardon
If that is correct picture of your starter relay see if jumping terminal 3 and 5 will make starter spin. Strange how the SAM module will energize control coil for the Circuit Opening Relay, but not for the Starter Relay, hmmm. If pin 5 was the one you found as ground terminal, jump straight battery power to it.
  • Loney911
7 years 5 months ago #29553 by Loney911
jreardon wrote: Is this what starter relay looks like?
Yeah same 4 terminal relay have
And Positive side is working
(Previously one is mistakenly said ground terminal is working)
So no ground is in starter relay
7 years 5 months ago #29554 by jreardon
Don't use a jumper wire on pin 1 and 2, bad idea. Use your test light.
  • Loney911
7 years 5 months ago #29555 by Loney911
jreardon wrote: If that is correct picture of your starter relay see if jumping terminal 3 and 5 will make starter spin. Strange how the SAM module will energize control coil for the Circuit Opening Relay, but not for the Starter Relay, hmmm. If pin 5 was the one you found as ground terminal, jump straight battery power to it.
Pin 2 and Pin 5 has positive power
When relay is energized pin connected to pin 3
7 years 5 months ago #29556 by jreardon
Put your test light in series with Pin 1 and Pin 2. If light does not light in crank position, then, well, let's just say something's not right.
Do you have computer communication with scanner?
  • Loney911
7 years 5 months ago #29559 by Loney911
jreardon wrote: Put your test light in series with Pin 1 and Pin 2. If light does not light in crank position, then, well, let's just say something's not right.
Checked pin 1 and pin 2 in series it’s not working
And did scanning too there are only 2 - 3 fault
SRS fault
Transmission fault
There is no fault related to crank or Start
7 years 5 months ago - 7 years 5 months ago #29560 by jreardon
Is this a manual or automatic? (I'm looking at the clutch circuit) imgur.com/a/xDrdF95
  • Loney911
7 years 5 months ago #29571 by Loney911
jreardon wrote: Is this a manual or automatic? (I'm looking at the clutch circuit) imgur.com/a/xDrdF95
Its a automatic
  • Loney911
7 years 5 months ago #29610 by Loney911
Do you have wiring diagram ?
Time to create page: 0.433 seconds
