Downstream O2 sensor voltage drops durring acceleration Normal?
- Drunken Elvis
There is a slight possibility of a minor exhaust leak 12 inches after of the second O2 sensor. Car runs very well.
I have a simple scan tool but it is not capable of storing live data so I cannot post a graph of what is happening. The up steam O2 sensor fluctuates as normal.
Question is...
I was watching the live data while my wife drove in the city and when under acceleration the voltage from the down stream O2 sensor would drop to .1 volts for a second or two. Normally it was fairly steady at around .7 volts but not when accelerating. Is this normal or the sign of a worn CAT? Faulty down stream O2 sensor?
Someone correct me if I'm wrong.
- Drunken Elvis
I have had my hands all around the exhaust and cannot fine a leak but the wire mesh around the flex pipe is partly missing. So I suspect a minor leak.
- guafa
- Thank you received: 80
You can check for a exhaust leak by restricting the out of the pipe.
One person can do it for you and you can hear the gases going out through the leak
- Drunken Elvis
Also considering performing a propane enrichment test to gauge the condition of the catalytic converter but I don't have the best equipment for that. The P0420 has not come back for a while but if it does, I'll have to investigate further.
- guafa
When mid aceleration, when upstream went rich (let's say 0.7v), downstream followed same voltage. Sometimes a little bit lower (let's say 0.5v).
Never downstream went to 0.1v
- Drunken Elvis
Drunken Elvis wrote: That's not a bad idea. I was thinking of hooking my shop vac backwards [blowing] into the exhaust pipe but Im afraid of pushing debris into the cylinders.
I'm actually OK with this idea.
To answer your first question, it certainly sounds like a catalyst issue. Manifolds and flex pipes are also suspect on that engine.
- Deltron
- Thank you received: 5
- Jasondo
Jasondo wrote: Tyler would you be able to show us exactly what you use for exhaust leak testing and where you got them. I like that idea.
I bought one of these, but any brand will do:
www.amazon.com/OTC-6522-10-Leak-Tamer-Adapter/dp/B00KIL0P0Q
Added an air regulator to the hose end with a worm clamp, and a gauge.
One warning: It's possible to add a LOT of pressure to an exhaust system this way, which can 'create' leaks that otherwise wouldn't be there under normal operation. Take care to add a reasonable amount of pressure (5 PSI-ish).
- Drunken Elvis
An exhaust leak from the flex joint, a good 12 inches downstream of O2 sensor number 2, was becoming more evident [louder]. I can only assume the P0420 code was the result of this leak. Twice before this car has set a P0420 code when the same flex coupling developed a leak, I had just never seen the 2nd O2 sensor voltage drop so low but that's probably what it was.
