Plug catalyctic and injector ramp
  • A93320336@gmail.com
  • A93320336@gmail.com's Avatar Topic Author
7 years 5 months ago #29831 by A93320336@gmail.com
Plug catalyctic and injector ramp was created by A93320336@gmail.com
Good day
I need to understand
If the catalystic is plug system will be rich or lean?
Injector ramps look ok it have pintal micanical movement is that mean the flow rate is ok or it meen the injector jest open how to know bad injector from current ramp ?
7 years 5 months ago #29908 by Tyler
Replied by Tyler on topic Plug catalyctic and injector ramp
If the trims and O2's go rich or lean... depends. :silly: If it's a single bank MAP or MAF system, you'll likely see rich (negative) trims. If it's a MAF system with two banks, you'll see negative trims on the bank with the plugged cat.
The injector pintle hump only tells you mechanical movement took place, nothing about flow or spray pattern quality. You'll only pick up a bad injector with a voltage or current ramp if there's something wrong with the pintle movement of the injector.
The following user(s) said Thank You: A93320336@gmail.com
