Brake lights stay on
  • aktoolpusher
  • aktoolpusher's Avatar Topic Author
7 years 5 months ago #29836 by aktoolpusher
Brake lights stay on was created by aktoolpusher
I'm working on a 2011 GMC 1500. The brake lights stay on. I have code co455 and co 161 if you push on brake pedal the brake light go off. With the plug to the brake light switch disconnected I have power in cruise/etc/tcc brake signal wire not sure where to go from here
7 years 5 months ago - 7 years 5 months ago #29840 by jreardon
Replied by jreardon on topic Brake lights stay on
See if voltage on 4 wires to Stop Lamp Switch (Top of Brake Pedal Assembly) is correct. Pink wire need car running I believe to have voltage.
Brakes not depressed:
org/wht - 12v
ppl - 12v
pink - 12V
lt blu/wht - 0v
Brakes depressed:
org/wht - 12v ref
ppl - 0v
pink - 12v
lt blu/wht - 12v
Last edit: 7 years 5 months ago by jreardon. Reason: read diagram incorrectly, updates correct voltages
7 years 5 months ago #29842 by jreardon
I read diagram wrong, I've updated post with correct voltage.
  • aktoolpusher
7 years 5 months ago #29843 by aktoolpusher
Replied by aktoolpusher on topic Brake lights stay on
the ltblu/wht wire has voltage when pedal is not depressed
7 years 5 months ago - 7 years 5 months ago #29845 by jreardon
aktoolpusher wrote: the ltblu/wht wire has voltage when pedal is not depressed
Does it change when pedal is pressed? What is voltage with switch disconnected?
edit: okay this was already answered in first post, sorry.
Take reading on this wire again when you disconnect harness from BCM. Connector is labelled X5. Possible this wire might be shorted to power, or maybe coming from BCM.
i.imgur.com/6UXh39Z.png
  • chief eaglebear
  • chief eaglebear's Avatar
7 years 5 months ago #29847 by chief eaglebear
Replied by chief eaglebear on topic Brake lights stay on
hi aktoolpusher are you in anchorage I am looking for good techs to hang with for technical experience
7 years 5 months ago #29850 by PDM
Replied by PDM on topic Brake lights stay on
chief eaglebear wrote: hi aktoolpusher are you in anchorage I am looking for good techs to hang with for technical experience
Alaska? I thought he was a Serbian arms dealer.
^sarcasm
7 years 5 months ago - 7 years 5 months ago #29883 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Brake lights stay on
Nearly all brake light switches these days are Hall Effect sensors and have two separate circuits as the throttle pedal sensors each circuit eorking the opposite sense as a failsafe i.e. one circuit is N.O. the other N.C. in the rest position. As with ABS speed sensors the clearance between the switch and the moving part is ultra critical, even if the switch is slightly loose on its mounting it can cause an issue.
Last edit: 7 years 5 months ago by Andy.MacFadyen.
  • aktoolpusher
7 years 5 months ago #29992 by aktoolpusher
The brake light switch is not the problem
