2009 murano passenger front window notworking from master switch
- cheryl hartkorn
- Thank you received: 130
7 years 5 months ago #29858
by cheryl hartkorn
2009 murano passenger front window notworking from master switch was created by cheryl hartkorn
im looking at the wiring diagram and see there is only one wire from the master switch that goes to the passenger switch. i used serive information and tested that line with a scope. had 2 channels hooked up and the communication looks exactly the same on master switch vs passenger switch. no data pids in scanner to see if bcm recognized the switch was being pressed. tried doing bi directional test to roll down windows with scanner but none had the function autel launch snap on. must only be an option on the factory scanner. so im about to just throw a master switch in it and see. what testing do you reccomend? from looking at a diagram
7 years 5 months ago #29864
Replied by Andy.MacFadyen on topic 2009 murano passenger front window notworking from master switch
Some of these switches can be dismantled and cleaned
7 years 5 months ago #29881
Replied by Chad on topic 2009 murano passenger front window notworking from master switch
It looks like M119 Pin 132 (GRN) on the BCM is a communication line between BOTH switches? And, M118 Pin 2 (GRY) is power to the switches. Do you have Power on Pin 10 of the Passenger switch?
- cheryl hartkorn
7 years 5 months ago #29897
by cheryl hartkorn
Replied by cheryl hartkorn on topic 2009 murano passenger front window notworking from master switch
yes i have power at the passenger switch. checked that. the window works from passenger switch but not master switch
7 years 5 months ago #29975
Replied by Tyler on topic 2009 murano passenger front window notworking from master switch
I actually just replaced a master switch in one of these for a battery draw issue. Switch wouldn't STFU and kept chattering on that LIN network hours after the key was out. :silly:
All the SI I could find says that line operates during the 'power window timer'. But that can't be, because the master switch HAS to be able to tell the passenger switch to roll the window down.
They only share the retained power and the LIN.
It sure sounds to me like it's time for a master switch, if you haven't replaced it already. Around ~$100 from the dealer.
