Misfire at rav
  • A93320336@gmail.com
  • A93320336@gmail.com's Avatar Topic Author
7 years 5 months ago #30074 by A93320336@gmail.com
Misfire at rav was created by A93320336@gmail.com
Good day
Toyota Camry 2009 4 cylinder 2.4l
It have dead misfire at accelration between 1 and 2 rpm and then it will be ok from 2 rpm
I do cylinder drop test all look ok
I remove air filter it is ok
I remove airfuel sensor and it stil misfire
It have no misfire counter
I remove spark and clean it it look normal
I can not cheack fuel pump presser due no serves port to hook my geage
At ideal it look ok jest when i rev it
Thes come after havey rain
Iclean mas by break clean
Mas air flow at rpm670 it read 2.1 gm/s at 1000rpm 4.78 at 3600 14.8 gm/s at4400 20gm/s
At 670rpm my fuel term long l19.5 short 8
Alt 2000 rpm long 19.5 short 7.8
At 3600 long 19.5 short 10.1
At 4400 long 19.5 short 0
Af oxygine sensor is read
At ideal -0.02mv 3.26v 1.007 times
At2400rpm -0.12mv 3.12v .991 times
At 4200 -0.11mv 3.11v .965 times
Plz any help
I have autel scoop and low amp clamp
7 years 5 months ago - 7 years 5 months ago #30082 by guafa
Replied by guafa on topic Misfire at rav
Hi sir,
Do you have also MAP readings? This readings can tell us whether there is or there is not a vacuum leak
MAF reading 2.1 g/s at idle is a little bit low (should be at 2.8 or something). This depends on rpm.
670 rpm are also low
for a 4 cylinders engine (which also tell us there is a vacuum leak in an engine with MAF). Do you know desired rpm?
Fuel trims are telling you PCM is always adding fuel. I would find the way to measure fuel pressure.
Also, if fuel pressure regulator has a vacuum hose, unplug it. This vacuum line decreases fuel pressure at low rpm.
That way you put maximum pressure in fuel system at idle or low rpm
Last edit: 7 years 5 months ago by guafa.
7 years 5 months ago #30088 by A93320336@gmail.com
Replied by A93320336@gmail.com on topic Misfire at rav
No map on it
Fuel regltor with no hose on it
7 years 5 months ago #30090 by cj1
Replied by cj1 on topic Misfire at rav
MAf should be reading much higher maybe around 50 gs at 4400 rpm
7 years 5 months ago #30093 by guafa
I suggest you the following.
Take the car for a spin. At wot, look for calc. load and oxygen sensor voltage in the scanner.
O2 sensor should be rich at wot all the time and and calc. load should be more than 85%
In order to have enough time to observe data, a climb hill would be better.
Let us know your results
7 years 5 months ago #30234 by A93320336@gmail.com
Fix
Clean the injector
7 years 5 months ago #30236 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Misfire at rav
Interesting because of the heavy rain symptom I was leaning towards a shorted ignition secondary issue
Time to create page: 0.359 seconds
