FORD TRANSIT 2015 T-250 - No Crank/ Start
- forumoto
- Christ De KING
Engine-: 3.7 Gas
This car has no crank or start issue. There is apparent one error code reported in the pcm.
P06E9:00-2F Engine starter performance
I sincerely need help on this issue. Any diagram information could help or other suggestion, car had a hit at the back or tail door..
Christ De Way Maker
Have you any diagnostic software that can read the status of the clutch pedal switch ?
- forumoto
- Christ De KING
And the code is permanent, it does not erase when you try to erase codes
Christ De Way Maker
- forumoto
- Christ De KING
Christ De Way Maker
If that circuit was damaged during the hit, that'd explain the code and the lack of cranking. I'd start with voltage checks at the starter relay, specifically at pin #1 and 2 for the control side. KOEO and KOEC. Missing power or ground will enable you to pick a direction to go, AND allow bypass testing to verify starter function.
- cheryl hartkorn
- Thank you received: 130
- forumoto
- Christ De KING
Now I have, the Van is the type that has been convented into bus, so it has seats inside, done by the manufacture already..
So if you said could be door switch, can you through more light into how that door switch work here and any diagram will also explain.
I also thank the poster of the diagram above, it means much to me for this check up and will take the time to cross check the starter relay as said by one poster and will update the thread.
I also need the CAN wiring diagram info. Because I am suspecting May be some CAN might have been damaged during the hit at the back tail door, below,
Once more time thanks for the various input, kudos to all that has put in much to make this a little easier in checking...
God bless thee all..????
NB-: I forgot to mention one code also concerning brake boost fault that messsage on the ipc,
In the abs module ,
Brake booster pressure sensor - c0047-16-08,
And then vacuum pump control circuit A- open p258A-14-48
A diagram display will also do here please, if you can share. Thanks
Christ De Way Maker
forumoto wrote: So if you said could be door switch, can you through more light into how that door switch work here and any diagram will also explain.
Not specifically, unfortunately.
Not all conversions inhibit starting, either. :silly: So I'd suggest keeping it simple with the relay testing first. Power to the control side comes from the Audio Front Control Module, ground comes from the BCM.
- Landroverman1958
- Thank you received: 17
