2011 GMC Terrain 2.4L SLE : Overheating and no hot air blowing from heater core
7 years 4 months ago #30738
Replied by Tyler on topic 2011 GMC Terrain 2.4L SLE : Overheating and no hot air blowing from heater core
That's definitely one to keep in mind for the future. :ohmy: Thanks for the follow up.
I'd be very interested to see how the chain was sitting on the water pump sprocket when they took the timing cover off. The sprocket had to have been at least trying to spin with the chain, otherwise Robert wouldn't have been able to drive it as much as he did.
- robert.lesaca
- Thank you received: 19
7 years 4 months ago #30816
by robert.lesaca
Replied by robert.lesaca on topic 2011 GMC Terrain 2.4L SLE : Overheating and no hot air blowing from heater core
Yes, the engine would struggle when overheated...i guess PCM wanting to protect engine by shutting down which is what owner experience.
THANKS all...
THANKS all...
- chasencai
- Thank you received: 3
7 years 4 months ago #30837
by chasencai
Replied by chasencai on topic 2011 GMC Terrain 2.4L SLE : Overheating and no hot air blowing from heater core
I find a car repair blog on your problem,and i share it here,hope it can help forum friend.
www.car-auto-repair.com
- TheTechWhisperer
- Thank you received: 47
7 years 4 months ago #30887
by TheTechWhisperer
"You will always find the greatest fulfillment in life when you are operating in the gifts God gave you"- Dad
National Director of Technical Training & Mechanical Operations - Express Oil Change & Tire Engineers
ASE Master L1 Tech
BMW Master Tech
Ford FACT Advanced Electronics Instructor
Replied by TheTechWhisperer on topic 2011 GMC Terrain 2.4L SLE : Overheating and no hot air blowing from heater core
I've seen at least 10 of these ecotecs with broken water pump chains just this year. You just take the 3 bolts off the access cover and try to move the gear with your finger (engine off obviously). If the gear moves, the chain is broken. The local parts stores stock the whole kits with guides, because it is so common.
I didn't read through the comments, so if someone already suggested this, then just ignore me
ASE Master L1 Tech
BMW Master Tech
