toyota celica 1995 electrical problem
- christophe
7 years 5 months ago #30255
by christophe
toyota celica 1995 electrical problem was created by christophe
this celica starts,runs smoothly ,for 1 minute, [sometimes less,] then stops.no spark at theplugs. have replaced the distributor, same thing. 12.5 volts on the coil feed ,and 0.7 on the 4pins of the other connector.[??] any ideas.rgds. chris
7 years 5 months ago #30256
Replied by Andy.MacFadyen on topic toyota celica 1995 electrical problem
Is the fuel.pump.relay still.closed and supplying power to the fuel.pump when it cuts out?
The following user(s) said Thank You: christophe
- christophe
7 years 5 months ago #30277
by christophe
Replied by christophe on topic toyota celica 1995 electrical problem
the fuel pump has NOTHING to do with no spark . thanks chris
- christophe
7 years 5 months ago #30278
by christophe
7 years 5 months ago #30279
Yes but if you loosing both spark and fuel it puts the diagnosis on a different path
7 years 5 months ago #30281
Replied by Noah on topic toyota celica 1995 electrical problem
Hi Chris, I merged your topics because I noticed you had duplicate posts about the same problem in different parts of the forum.
Try to keep questions about the same problem in one thread please to avoid confusion and to keep it easier for anyone trying to assist you.
Thanks
Thanks
- christophe
7 years 5 months ago #30307
by christophe
Hi Thanks for your reply But there is no problem with fuel.and there is 12.5 volts on the coil, and 0.7 volts on the 4 pins of the other distributor connector. when it stops.rgds. chris
- John Curtis
- Thank you received: 111
7 years 5 months ago #30308
by John Curtis
Replied by John Curtis on topic toyota celica 1995 electrical problem
When this event occurs does it stop getting fuel? Have you tested it when the condition is actually happening?
We understand that the vehicle is getting fuel but when the problem actually occurs it might actually not be getting fuel. We have to assume you haven’t checked it during the time of fault. It’d be better to actually leave the fuel pressure gauge tested while the event of failure occurs.
Also have you checked any sensors for 5V ref when it is acting up?
Andy is asking because it changes the direction. Could be a whole list of things.
7 years 5 months ago - 7 years 5 months ago #30315
What's the engine size in your Toyota Chris?
I was going to have some coffee and look at a diagram for you, but it looks like there's 2 engine options. It would also be helpful to know if it is California or Federal emissions. That might sound stupid, but we get a fairly good mix of both in Massachusetts. Depending on what state you live in, you could have either. Assuming you're in the states that is...
Last edit: 7 years 5 months ago by Noah.
Time to create page: 0.376 seconds
