1999 silverado 5.3 5 volt circuit short
- Ljs
7 years 4 months ago #30576
by Ljs
1999 silverado 5.3 5 volt circuit short was created by Ljs
I have a 99 5.3 silverado with a 50k engine in it, I've been constantly looking for a 5 volt short, truck runs ok with a low level random misfire, the only indication is a fuel tank pressure sensor circuit code, it's not there tho, it's somewhere else, please advise,
- chief eaglebear
- Thank you received: 70
7 years 4 months ago #30597
by chief eaglebear
Replied by chief eaglebear on topic 1999 silverado 5.3 5 volt circuit short
hi sir can you put upa diagram - do you have a 5 vref established if your trying to find short that may be difficult ona 5 vref circuit but its possible im not sure the fuel pump uses 5 volt ref line
- chief eaglebear
7 years 4 months ago #30598
by chief eaglebear
with an intermittent short on 5vref line the truck may cut out if its loosing crank signal maybe scope your crank signal if you have scope -
- John Curtis
- Thank you received: 111
7 years 4 months ago - 7 years 4 months ago #30604
by John Curtis
Replied by John Curtis on topic 1999 silverado 5.3 5 volt circuit short
What checks have you done?
Is there a particular reason you’re concerned with reference voltage?
If you’re having a misfire you probably want to run through the basics first.
Fuel
Air
Spark
Timing
Exhaust
Compression.
Probably not in that order.
Is it a random misfire?
Is it one particular cylinder?
What are your fuel trims and 02s telling you?
Fuel
Air
Spark
Timing
Exhaust
Compression.
Last edit: 7 years 4 months ago by John Curtis.
