[FIXED] chevy c1500 p0300 help!!
  • johnathon.balderas
  • johnathon.balderas's Avatar Topic Author
  • Stay humble and thank God everyday for waking up.
9 years 10 months ago #4063 by johnathon.balderas
1998 chevy c1500 p0300 help!! was created by johnathon.balderas
Diagnosing my uncles truck. He had it smogged in April. I have the emissions test results. The only gas that is high are HC's
He recently replaced the injectors and did plugs and wires cause the truck was running bad. Well after the repairs the truck ran fine according to him. Well a few weeks go by and the truck starts running bad again and eventually ceases to run. Well I come look at it and hook up a fuel pressure gauge and find that it builds 50 psi of fuel pressure but quickly goes to zero when the pump shuts off.
9 years 10 months ago #4064 by johnathon.balderas
Replied by johnathon.balderas on topic 1998 chevy c1500 p0300 help!!
So I open the throttle plate and see a bunch of fuel spraying into the intake. Well we remove the intake and find the fuel pressure regulator spraying fuel out of the vacuum side. So we replace it and no more fuel spraying out and put everything back together. The truck fires up now and runs but misfires. I hook up my scan tool and see the short term fuel trim -30 on both banks. And I check fuel pressure and it's 0psi. Wth this doesn't make sense. Any help is appreciated.
9 years 10 months ago #4065 by johnathon.balderas
Here is a pic of the smog results
9 years 10 months ago #4066 by johnathon.balderas
9 years 10 months ago #4067 by Noah
Replied by Noah on topic 1998 chevy c1500 p0300 help!!
Welcome to the forum, thanks for posting!
It sounds like there's a leaking injector or leaking fuel pump check valve. You'll want to block the return line to the tank and see if the fuel pressure continues to bleed down. If it does, then you know there's a leak from one if the injectors. If it doesn't still bleed off, then the fuel pump check valve is to blame.
Check out this lecture for a description of both scenarios and tips for troubleshooting.
9 years 10 months ago #4068 by Noah
johnathon.balderas wrote: So I open the throttle plate and see a bunch of fuel spraying into the intake. Well we remove the intake and find the fuel pressure regulator spraying fuel out of the vacuum side. So we replace it and no more fuel spraying out and put everything back together. The truck fires up now and runs but misfires. I hook up my scan tool and see the short term fuel trim -30 on both banks. And I check fuel pressure and it's 0psi. Wth this doesn't make sense. Any help is appreciated.
Sorry, didn't know you were still posting!
The ruptured regulator explains the pressure bleed down, looks like you got that nailed down.
As for the 0 psi reading, if the truck is running I'd not trust that gauge. The negative fuel trims seem normal based on the extra fuel leaking into the intake and may need time to relearn or may need to be reset.
Also, there's the possibility of fuel contaminated oil from the leak. This could cause a rich condition and negative trim numbers due to fuel vapor being breathed in through the PCV system
The following user(s) said Thank You: johnathon.balderas
9 years 10 months ago #4069 by johnathon.balderas
The fuel pressure isnt bleeding down anymore it just is non existant. I was getting 50 psi when pump was running and then it would drop to zero after punp shut off so i found the regulator not just leaking but spraying fuel out. So we replaced it and no leaks but I hook my gauge up now and I get zero psi.
9 years 10 months ago #4072 by Noah
If the truck is running, it cannot actually be at 0 psi. :huh:
I feel like there's possibly a problem with the gauge or connection.
9 years 10 months ago #4073 by Noah
Is there a button on the side of the gauge to purge air that may be trapped in the gauge?
9 years 10 months ago #4082 by johnathon.balderas
Ok the fuel in the crankcase makes sense. I noticed that when the truck was idling the oil pressure was really low and my uncle said that he never saw it dip that low. So I'm advising my uncle to change the oil and then we can go from there.
9 years 10 months ago #4083 by johnathon.balderas
We also noticed that if we pulled the pcv hose off its ran a lot better, not perfect but significantly better.
9 years 10 months ago #4090 by Noah
Good deal, keep us posted!
9 years 10 months ago - 9 years 10 months ago #4140 by johnathon.balderas
Replied by johnathon.balderas on topic Fixed!! 1998 chevy c1500 p0300 help!!
Thank you Noah for the fuel contaminated oil idea. Oil change was right on the money. Fuel contaminated oil crossed my mind but having not seen it personally and not realizing it could cause that rich of a condition I dismissed it. Thank you everyone
Last edit: 9 years 10 months ago by johnathon.balderas.
9 years 10 months ago #4146 by Noah
Replied by Noah on topic Fixed!! 1998 chevy c1500 p0300 help!!
Great, glad it's fixed! Thanks for updating us.
Did you ever figure out what was going on with that fuel gauge?
9 years 10 months ago #4147 by johnathon.balderas
No I hooked it up to my truck and it gave me a reading so idk.
