99 NAVIGATOR 5.4 MODE $6 ID:21 00 N/A,41 12, 56 00 TESTS FAILED ?????
  • Chicho68
  • Chicho68's Avatar Topic Author
7 years 4 months ago #30897 by Chicho68
99 LINCOLN NAVIGATOR 5.4 CAN'T PASS EMISSION TEST WITH NO CHECK ENGINE CODES ONLY I FOUND ON MODE $6 TESTS FAILED ON THIS
ID:21 00 N/A TEST FAILED
ID:41 12 N/A TEST FAILED
ID:56 00 N/A TEST FAILED
WHAT THIS MEANS , I CAN'T FIND A LIST FOR THIS ID'S
HOW CAN I CHECK EMISSION SYSTEM ON AUTEL MAXIDAS DS808?
THANKS.
7 years 4 months ago - 7 years 4 months ago #30919 by Tyler
What was the specific reason for not passing emissions? You say there's no codes, so not enough I/M monitors have completed?
Are you sure that these tests failed? Or are just incomplete?
TID $21 00 is part of the EVAP monitor, for the .040" leak test. TID $41 12 is part of the EGR 'hose check' monitor, to make sure both DPFE hoses are connected to the sensor. TID $56 00 is part of the misfire monitor.
All the emissions information and Mode $06 TID's are available for free from Ford:
www.fordservicecontent.com/ford_content/...orcraft/obdsm99b.pdf
www.motorcraftservice.com/freeresources/obd
Last edit: 7 years 4 months ago by Tyler.
The following user(s) said Thank You: Chicho68
