99 GMC Jimmy Starting issue
- Mort
7 years 4 months ago #31176
by Mort
99 GMC Jimmy Starting issue was created by Mort
Working on a 99 GMC Jimmy 4.3 4WD did an engine swap on the jimmy got everything back together tried to start it and it cranks but doesn't start, however if I put fuel down the intake and crank it it will start and run. It is not throwing any codes so I am sort of at a loss as to wear to start the troubleshooting Any ideas out there?
- Cheryl
- Thank you received: 215
7 years 4 months ago #31177
by Cheryl
Replied by Cheryl on topic 99 GMC Jimmy Starting issue
You have fuel pressure??
- Mort
7 years 4 months ago #31183
by Mort
Replied by Mort on topic 99 GMC Jimmy Starting issue
I haven't put a gage to it. I am thinking the fuel pump was the culprit, but wouldn't it throw a code for low fuel pressure
- Cheryl
7 years 4 months ago #31184
by Cheryl
Doubt it. It’s to old for that
- Mort
7 years 4 months ago #31189
by Mort
I'll check the fuel pressure when I get home Sunday
- Cheryl
7 years 4 months ago #31192
by Cheryl
Might check the grounds. Is the frame grounded? Cause if not the pump won’t have a ground
- Mort
7 years 4 months ago #31247
by Mort
Ok Turning the switch to the on position, fuel pressure is 55 psi. when cranking it drops to 40 psi. I can zero it out and turn the switch on and it jumps to 55 psi So to me this indicates the fuel pump is working. Shut the switch off and it starts to drop off. Am I correct in assuming this indicates a bad fuel regulator?
- Cheryl
7 years 4 months ago #31250
by Cheryl
That cranking pressure is way to low. The popper valves won’t open on the injectors.
- Mort
7 years 4 months ago #31270
by Mort
If my gauge is is showing 55 psi with the switch on but drops off when cranking is that not indicative of a bad fuel regulator?? The battery is new and my customer says there is a new fuel pump in the tank.
- jreardon
- Thank you received: 198
7 years 4 months ago #31272
by jreardon
Replied by jreardon on topic 99 GMC Jimmy Starting issue
Fuel Pressure is low. Is your the SFI or CSI (spider injectors) ? Pinch off the return line switch key to on position and see if pump is strong enough to push the psi roughly 80-90 psi. If this pump passes this test, then change the regulator. Don't forget to change out the fuel filter while you're there.
- Mort
7 years 4 months ago #31284
by Mort
Thank you for that info. I was looking for a way to check the Regulator and couldn't find it in my manual..
