1987 Jeep YJ 4.0 Swap No Injector Pulse
- Taylorc23
7 years 4 months ago - 7 years 4 months ago #31434
by Taylorc23
1987 Jeep YJ 4.0 Swap No Injector Pulse was created by Taylorc23
Hello! I have been stumped on this issue for the last couple of months now, I have a 1987 YJ and am doing a 4.0/AW4 swap out of a 2001 Jeep Cherokee. I grabbed the entire engine bay wiring harness as well as the TCU and ECU. I have my basic wires to fire spliced in according to every 4.0 forum I have read. tHere is a video of the exact same swap with the exact same donor functioning correctly, seemingly wired the exact same way I have my setup. I have had the ECU reprogrammed to remove the SKIM immobilizer, as well as replaced the crankshaft position sensor. The Jeep was running before the engine was pulled, original harness has NOT been spliced into, or thinned it is all original just tapped into the YJ harness as the wiring write ups suggest. The Jeep will run on starter fluid but there is no injector pulse, and the ASD relay is not functioning correctly. Have now tried 3 ecu's, ohm'ed out all of my grounds and still no avail. I have an OBD2 port wired up but only get a link error. I can't wire up the gauge cluster I don't have which I assume is why the diagnostics doesn't work..According to my diagrams the one wire I'm missing goes to the Cluster .. If I can't figure it out soon I plan on pulling the entire harness again and going with a Holley Sniper TBI, any experience with that? If I do go to the Holley TBI and decide to keep my AW4, how do I go about removing the TCU from the main harness? What can I keep and what should I remove from the harness to keep it as clean as possible? I'm sorry for my lack of knowledge, I am 19 and have been building this Jeep for the last four years, only to find that once it is all together and painted, I have a very pretty paper weight that I cannot get to start for the life of me. Have replaced all relays, checked all fuses. I'm stumped.
Last edit: 7 years 4 months ago by Taylorc23.
- tim.smith1
- Thank you received: 61
7 years 4 months ago #31439
by tim.smith1
Replied by tim.smith1 on topic 1987 Jeep YJ 4.0 Swap No Injector Pulse
Not sure I can help with this but I will try. Have you tried to message the person that did the swap on YouTube video of not that would be the best place to start. Second I would talk to the company that did the delete on the Ani theft to see if you can verify that that is working properly. Third can you scan it and if so what if any are the codes?
- Cheryl
- Thank you received: 215
7 years 3 months ago #31645
by Cheryl
Replied by Cheryl on topic 1987 Jeep YJ 4.0 Swap No Injector Pulse
Can you post a wiring diagram?? Of the asd relay??
- tim.smith1
7 years 3 months ago #31649
by tim.smith1
not sure who you are asking or what you need?
Cheryl wrote: Can you post a wiring diagram?? Of the asd relay??
- Cheryl
7 years 3 months ago #31658
by Cheryl
The original thread says the asd relay isn’t functioning and on Chrysler the asd is responsible for a ton of things. I want to see if he’s missing a power feed or control from the pan to the relay.
The following user(s) said Thank You: tim.smith1
