Wiring diagram
- Nelixuk2003
- Thank you received: 2
7 years 3 months ago #32041
by Nelixuk2003
Wiring diagram was created by Nelixuk2003
Hi all
I’m based in the UK and I’m hoping someone on here might be able to help me out with wiring diagram for a 2011 Peugeot 4007. I have a message on the car saying check engine oil level, oil level is fine, I also have a P250B code when scanned with the Verus Pro, Oil pressure sensor signal open circuit or excessive temp. I just want to check if it’s the sensor or wiring issue.
Thanks
Thanks
The following user(s) said Thank You: A mechanic
7 years 3 months ago #32042
Replied by Noah on topic Wiring diagram
I don't have access to service info for your region, but the guided component test portion of your Verus might have the information you need to troubleshoot that circuit.
- Nelixuk2003
7 years 3 months ago #32056
by Nelixuk2003
Replied by Nelixuk2003 on topic Wiring diagram
My Verus Pro is not full up to date, currently on 13.2. The Verus shows minimal data for this car, the car is basically a Mitsubishi Outlander. I’ll take a look in the guided component section, I’m at work the next few days but I will update so if anyone else has a diagram or any info that might help I’ll check back and keep up to date.
Cheers
Derek
Cheers
Derek
- Landroverman1958
- Thank you received: 17
7 years 3 months ago #32060
by Landroverman1958
Replied by Landroverman1958 on topic Wiring diagram
Hiya what engine? would help engine code?
- Nelixuk2003
7 years 3 months ago #32063
by Nelixuk2003
Hi LanRoverMan1958
It's the 2.2 HDi (4HK)
Not sure of the engine code at the moment
- Landroverman1958
7 years 3 months ago #32066
by Landroverman1958
Usually it’s a combined oil level/oil temperature with a power ground and signal,you should be able to read it through the engine live data or body control module,look for input signals may take some locating,,,,,....
- Desmond6004
7 years 3 months ago - 7 years 3 months ago #32100
by Desmond6004
Not sure if this is the right one... [see attached pdf]
Replied by Desmond6004 on topic Wiring diagram
Last edit: 7 years 3 months ago by Desmond6004.
- Nelixuk2003
7 years 3 months ago #32129
by Nelixuk2003
Thanks, Desmond6004
I'll take a look and report back, I'm super busy at the moment so maybe a little while before I get to look further into this.
