caprice P0606 engine control module
  • Zakarya Al-Yafei
  • Zakarya Al-Yafei's Avatar Topic Author
9 years 10 months ago #4250 by Zakarya Al-Yafei
caprice P0606 engine control module was created by Zakarya Al-Yafei
Hello every one
I have carpice 2007 6V
the PCM set code p0606 in one condition
just when the rps gets more than 4000 rpm
I did clean the throttle body and replace spark plug
the rpm gets more (5500)
but the problem still there
when the rpm get about 5500
appear to me on message center
( low engine performance ) (safety mode )
as soon as I get this message I scan for DTC and I found P0606
any one have any idea about this code ?
do I need to replace ECM ?
or what do I have to do ?
thanks
9 years 10 months ago #4272 by Noah
Replied by Noah on topic caprice P0606 engine control module
P0606: Control Module Internal Performance
I don't have any service info for that car, but I think the only course of action is to check the powers and grounds to the computer.
If it's setting at 4000 RPM, check the powers and grounds at 4000 RPM and see if something is dropping out.
If that checks good, then I believe the only thing left to do is replace the computer.
The following user(s) said Thank You: Zakarya Al-Yafei
9 years 10 months ago #4275 by Tyler
Replied by Tyler on topic caprice P0606 engine control module
Yeah, these internal module codes are always tricky :unsure: I'm with Noah, monitoring powers and grounds above 4000 RPM is the way to go.
Curious that the code only sets above a certain engine speed, and that the maximum engine speed changed with the throttle cleaning... I know this thing isn't setting 5V reference circuit codes, but it may be worth monitoring them on a scope while the code sets.
  • Zakarya Al-Yafei
9 years 10 months ago #4410 by Zakarya Al-Yafei
Replied by Zakarya Al-Yafei on topic caprice P0606 engine control module
Thank you very much
I appreciate what you are say
9 years 10 months ago #4412 by Tyler
No problem! Let us know where this one ends up, if you get the opportunity ;)
