2009 Toyota Corolla misfire
  • tim.smith1
  • tim.smith1's Avatar Topic Author
7 years 3 months ago #32112 by tim.smith1
2009 Toyota Corolla misfire was created by tim.smith1
Anyone know the best way to find out why a ECM would be shutting number four injector pulse down. This car will idle in my shop for hours with no miss as soon as I get on the road it shuts number four injector off I have looked at coil ramps and swapped plugs and coils between cylinders also I have watched injectors and swapped them still number four. Looked at the cam and crank signals they seem fine. I drove it and watched scan data misfires I kinda feel like the ECM is seeing lots of miss fires on cylinder 4 right before it shuts off injector during that time I can't feel it in the car then boom when the ECM shuts off injector it is like night and day car stops having any power of course cause it turns into a 3 cylinder lol
7 years 3 months ago #32113 by Paul P.
Replied by Paul P. on topic 2009 Toyota Corolla misfire
tim, have you performed a relative compression test?
What are the fuel trims doing at idle and high rpm? Are the O2's responding properly?
Does the car have any unusual vibrations when in gear?
Thanks
Paul
Never stop Learning.
The following user(s) said Thank You: tim.smith1
7 years 3 months ago #32154 by pjjohnson
Replied by pjjohnson on topic 2009 Toyota Corolla misfire
mechanical, diagnose cylinder # 4 valve train, watch a vacuum gauge flutter for valve issues, running compression etc... swap injector too.
7 years 3 months ago #32167 by Cheryl
Replied by Cheryl on topic 2009 Toyota Corolla misfire
Does this Toyota actually have intentional shut down?? Or is it just a driver failing intermittently? I’d try unplugging a coil on another cylinder to see if the computer shuts the injector off. Just to see if it really is intentional shut down. Then go from there
  • tim.smith1
7 years 3 months ago #32181 by tim.smith1
Replied by tim.smith1 on topic 2009 Toyota Corolla misfire
moderator please delete the zippy share links i shared imo zippyshare is like a virus lol pop ups and i never could get the files to show up here is the same pids from a test drive notice how o2 and stft flat line these are mediafire. the secound group of pids is idle
www.mediafire.com/file/dftfk6rxrix7mgi/2...5_21.48.33.pids/file
www.mediafire.com/file/26ie6ei36qofhl2/2...5_22.16.57.pids/file
go to snap-on and download the free program shopstreamconnect to view files then open with shopstreamconnect.
  • tim.smith1
7 years 3 months ago #32182 by tim.smith1
the first one is both cams and the second one is injector that was in cylinder number four it has been moved to cylinder number one.
www.mediafire.com/file/szui8u8liuruist/t...9_both_cams.vsm/file
www.mediafire.com/file/5qpy5384a7ookm8/corrolla.vsm/file
7 years 3 months ago - 7 years 3 months ago #32186 by Tyler
Replied by Tyler on topic 2009 Toyota Corolla misfire
Deleted those links you mentioned, Tim. ;)
The ECM is definitely forcing open loop in response to a perceived misfire. Happened right after a part throttle acceleration. It's interesting that the upstream A/F sensor doesn't show a lean condition during the acceleration.
Like pjjohnson suggested, mechanical is definitely the next step. I've seen several of these engines blow head gaskets between cylinders.
Last edit: 7 years 3 months ago by Tyler.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
7 years 3 months ago #32188 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2009 Toyota Corolla misfire
i cant get the files to open
  • tim.smith1
7 years 3 months ago #32189 by tim.smith1
@cheryl hartkorn i had to make a folder in a area that shopstream could see and move the files there before i could find it with shopstream it was a challenge lol but i got it so i know it works
  • tim.smith1
7 years 3 months ago - 7 years 3 months ago #32190 by tim.smith1
i asked for help on iatn but i guess you cant reply to a help request that you started on iatn so i dont think i will be doing that again lol
Last edit: 7 years 3 months ago by tim.smith1.
7 years 3 months ago #32195 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2009 Toyota Corolla misfire
I am wondering if we could be looking at a break or short in the coil pack or injector wiring cusing the ecu to shutdown the injector.
7 years 3 months ago - 7 years 3 months ago #32207 by Tyler
tim.smith1 wrote: i asked for help on iatn but i guess you cant reply to a help request that you started on iatn so i dont think i will be doing that again lol
You can update your help request... Once. :( After that you have to close it within a certain amount of time. It's not a perfect system.
Has anyone been monkeying around with this thing before you? Wonder if an ECM got swapped at some point, and there's some kind of crank pattern learning required. Just speculating, since you've said you don't feel any misfires. :silly:
7 years 3 months ago #32230 by PDM
Replied by PDM on topic 2009 Toyota Corolla misfire
Are misfires detected by anything other than the crank sensor?
I guess a transmission problem could be a culprit
7 years 3 months ago #32232 by rockp2
Replied by rockp2 on topic 2009 Toyota Corolla misfire
I also have to agree with possible mechanical and doing a relative compression test. I chased a very similar misfire on a 2011 Sentra. I misread the waveform on the relative compression test, but once my error was pointed out by the experts on this forum, I did a mechanical compression test (which required removing the upper intake) and indeed had a significant loss of compression on the offending cylinder.
7 years 3 months ago #32241 by Andy.MacFadyen
Wrench on the the crankshaft pulley nut and feel the compressions
  • tim.smith1
7 years 3 months ago #32437 by tim.smith1
okay guys i know i did a relative compression test with the scan tool thru the functional test and compression looked good but i did not save that screenshot but i did get to drive this thing and i can confirm that data stream shows number 4 is missing right before the ecm shuts injector off it is kinda kewl because i can actually prevent injector shut down if i let off the throttle i also saw a couple misses on cylinder two i have two pid views showing me doing this on two different test drives.
www.mediafire.com/file/9zflp692zdopslb/2...1_17.16.15.pids/file
www.mediafire.com/file/6prj9gfluibi3dj/2...1_17.35.49.pids/file
because i did not save the compression test screen shot and this looks more and more like mechanical problem i decided to revisit the compression this time with a gauge it showed between 165 and 175 per cylinder i then decided to do a running compression test with the gauge (since i dont have a kewl pressure transducer for my scope ) it seemed that it was about 40-50 hard to read of course and around 80 to 100 psi on a snap throttle all cylinders the last thing i did was a cylinder leak down with shop air it seems that an exhaust valve is leaking on cylinder two all the other cylinders seem to be great including number 4 just wanted to close this one out sorry for the delay i have been crazy busy.
again i cant say it enough thanks to all that helped and thanks for all you guys do!!!!!!!!!!!!!!!!!!!!!
Time to create page: 0.326 seconds
