2001 Tacoma 2.4l p0171 too lean
  • johnathon.balderas
  • johnathon.balderas's Avatar Topic Author
  • Stay humble and thank God everyday for waking up.
9 years 10 months ago #4302 by johnathon.balderas
2001 Tacoma 2.4l p0171 too lean was created by johnathon.balderas
Have a 2001 tacoma in my shop with a lean code p0171. Long term fuel trim is 29% Short term is at around zero. Scoped maf sensor and got 4.35 volts at a snap test. Not sure where else to look. Any help would be appreciated
9 years 10 months ago #4303 by OBD Rick
Replied by OBD Rick on topic 2001 Tacoma 2.4l p0171 too lean
Hi,
Classic start with a check on freeze frame data to identify what conditions the code was set in (idle? / under load?) Or just pull up live data and check fuel trims at idle and at 3k rpm.
If trims improve at higher rpm most likely the classic vacuum leak etc, if trims don't improve or get worse then possidly a fuel delivery problem.
Have a play on live data and let me know the results
Calling upon my years of experience, I froze at the controls. – Stirling Moss
9 years 10 months ago #4308 by johnathon.balderas
Replied by johnathon.balderas on topic 2001 Tacoma 2.4l p0171 too lean
Fuel trims increase with acceleration. 30% at idle and 39 when accelerating. But normal at wot.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
9 years 10 months ago #4309 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2001 Tacoma 2.4l p0171 too lean
what is the fuel pressure reading? done an injector balance test yet? maybe restricted.
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
9 years 10 months ago #4311 by ScannerDanner
Replied by ScannerDanner on topic 2001 Tacoma 2.4l p0171 too lean
johnathon.balderas wrote: Fuel trims increase with acceleration. 30% at idle and 39 when accelerating. But normal at wot.
Acceleration and WOT is not when you want to be looking at trim numbers.
Give us an idle (I think you did already) and a steady 2500-3000 rpm reading in park. Hold it there for a minute to let it stabilize.
Don't be a parts changer!
9 years 10 months ago #4315 by johnathon.balderas
Fuel trim climbs when I hold the throttle steady. Added propane to the intake to see if the ft would decrease it did. How high can the fuel trim numbers go?
9 years 10 months ago #4322 by johnathon.balderas
Going to check fuel pressure tomorrow
9 years 10 months ago - 9 years 10 months ago #4323 by rockp2
Replied by rockp2 on topic 2001 Tacoma 2.4l p0171 too lean
A new guy amateur question...isn't O2 feedback ignored at WOT? Kind of like being in open loop. Is that correct, or no? Would that explain why at WOT fuel trims are normal?
Last edit: 9 years 10 months ago by rockp2.
9 years 10 months ago #4325 by OBD Rick
Yeah in fact on alot of vehicles 8f you watch your loop status whilst on accell and WOT you will see it go into open loop at these times,
Jonathan's got the right idea, next step I would take in testing would be fuel pressure/volume check
9 years 10 months ago #4341 by johnathon.balderas
Fuel pressure is within spec. But according to mitchell while idling it's slightly too high. At idle it's supposed to be between 31 and 37 psi. I got 44 at idle. So I'm kind of stumped.
9 years 10 months ago #4342 by johnathon.balderas
Short term ft stays around 0 and long term is 28 to 33
9 years 10 months ago #4343 by JuniorGS
Replied by JuniorGS on topic 2001 Tacoma 2.4l p0171 too lean
Did you disconnect the vacuum line from the fuel pressure regulator & do a snap throttle test with the fuel pressure gauge? You want to make sure that the pressure doesn't drop out on this test.
9 years 10 months ago #4344 by johnathon.balderas
I just did and it doesn't drop
9 years 10 months ago #4346 by johnathon.balderas
Pinched off return and fuel trim got better. Fuel pressure went to about 70
9 years 10 months ago #4347 by johnathon.balderas
9 years 10 months ago #4364 by OBD Rick
So with increased fuel pressure the fuel trims got better, I wonder if your dealing with restricted injector(s) I think I'd be going up the route of injector balance test next for the moment
9 years 10 months ago #4366 by OBD Rick
Also just thought (I'm not familiar with the engine) is this a V engine? If so does the fuel trim correction apply to both banks?
9 years 10 months ago #4370 by johnathon.balderas
It's a 4 cylinder. Is it possible for a performance air filter to cause this issue?
9 years 10 months ago #4381 by borntoroll
Replied by borntoroll on topic 2001 Tacoma 2.4l p0171 too lean
johnathon.balderas wrote: It's a 4 cylinder. Is it possible for a performance air filter to cause this issue?
It is a possibility
9 years 10 months ago #4394 by matt.white
Replied by matt.white on topic 2001 Tacoma 2.4l p0171 too lean
Ignore the fuel trims but look at the o2 sensors at WOT. If it can hold good fuel pressure but still be lean (under .5v) I'd second blocked injectors.
Your peak maf voltage sounds ok but they're renowned for getting the resistors dirty. Check they're clean.
I have seen sports air filters give strange readings but not this bad. If it's an oiled filter that may have helped dirty the MAF.
Time to create page: 0.425 seconds
