2010 acadia engine in reduced power mode
7 years 2 months ago #32842 by vhehn
i have a 2010 acadia. it has check a engine light on and triangle light on. its flashing service stabilitrack and traction control and reduced power. it is currently in limp mode no acceleration. this car recently had a new timing chain installed. its showing codes p2119,p2101,p0221,p2176,p0100,p0113.
the codes point to a throttle body problem. so far i have replaced the throttle body with no change and the wiring tests ok. when you first turn the key on the throttle body responds to the acc pedal until the check lights go out on the dash. then the ecm seems to shut of the connection. can someone point me to where i should go next? i am suspecting an ecm.
here are some data points from my scanner app:
obd module voltage: 14.3
fuel system status: open loop due to engine load or fuel cut due to deceleration.
calculated engine load value; 100%
engine coolant temp: 210
short term fuel trim bank 1: 0% in neutral. -5.47 in drive if you put the car in drive you get a reading.
long term fuel trim bank 1: 0% 0%
short term fuel trim bank 2: 0% -3.91 in drive
long term fuel trim bank 2: 0% 0%
timing advance: -5-+3 bounces around
intake air temp: 89.6
maff air flow rate: 15.9 g/sec
throttle position: 32%
ox sensor1 bank 1 voltage: 0v in neutral. .74 in drive
ox sensor1 bank 1 stft: 0 in neutral -5.47 in drive
ox sensor bank2 bank 2 voltage: 0 in neutral. .6 in drive
ox sensor bank2 stft: nr nr
ox sensor1 bank2 voltage: 0 in neutral. .7 in drive
ox sensor1 bank2 stft:0 in neutral. -7.81 in drive
ox sensor2 bank2 voltage: 0 in neutral. .6 in drive
ox sensor2 bank2 stft: nr nr
fuel rail pressure: 503-639 bounces around
catalyst temp bank 1 sensor 1: 1468 (seems hi)
catalyst temp bank 2 sensor 1: 1401(seems hi)
control module voltage. 14.07
absolute load value: 47%
fuel air commanded ratio: 29.3%
relative throttle position: 18%
ambient air temp: 64.4
absolute throttle position b: 77%
absolute pedal position d: 19%
absolute pedal position e: 19%
commanded throttle actuator: 9%
long term secondary oxygen sensor trim bank 1: 0
long term secondary oxygen sensor trim bank 3:0
long term secondary oxygen sensor trim bank 2:0
long term secondary oxygen sensor trim bank 4:0
7 years 2 months ago #32858 by Ben
take a look at your pedal position % for all sensors with closed throttle and slowly open throttle to 100% and make sure they all agree all the time. it looks like your data shows a couple of them saying 18 or 19% and 1 saying 77%
