2008 driveability issues
  • ed begley
  • ed begley's Avatar Topic Author
7 years 2 months ago #32981 by ed begley
Replied by ed begley on topic 2008 driveability issues
i did have lower than normal fuel pressure 47 psi koeo after replacing fuel pump i had 55psi koeo , and when running needle fluctuation was less
i look foward to your volume test
thanks
7 years 2 months ago #33013 by simclardy
Replied by simclardy on topic Re:2008 driveability issues
How about a simple vacuum gauge on the intake manifold? It should show low vacuum with a leak. Some people claim it can tell you everything, i don't think so, but it should tell you something.
Sent from my SM-G930V using Tapatalk
7 years 2 months ago #33014 by Andy_
Replied by Andy_ on topic Re:2008 driveability issues
You don't have a vacuum leak. You said that when you raised the rpm's off idle that the fuel trims still stayed +20 something percent positive. Is that right? If so, you don't have a vacuum leak, and I wouldn't expect that to cause your low power issue.
I just skimmed the responses, so I apologize if I say something that someone else did or that I missed. What scan tool are you using? Are you able to record data on a test drive? You can probably pick out your problem by selecting the correct data and analyzing it. If you can record data let me know and I'll tell you what PIDs to record.
  • ed begley
7 years 2 months ago #33030 by ed begley
Replied by ed begley on topic Re:2008 driveability issues
i have a zurich zr 13 i dont know if it can record data while driving , i will check when i get home .i have been ubable to get a definitve answer as to where to hook up a vacuum gauge on a 2008 6.0 , earlier models had more vac ports , i do not have a vacuum booster. I am abffled as to why this affecting the entire left bank, i have pulled all plugs and all 4 on the left bank are snow white lean.I have performed a compression test all 150-160 psi . Another member suggested that my cleaning of the injectors could have actually blocked them , i am unsure as why this would be as i visually observerd the injectors go from a steady stream to a more conical spray pattern
As i said i will check if the scanner i have has recording capabilities
thanks ed
  • ed begley
7 years 2 months ago #33033 by ed begley
it looks as though my scanner will record , i have not tried it yet.
i did figure out where i can hook up a vac gauge i am getting 16 inches at idle, which i suppose it is not to bad considering it is running so poorly
it is still baffeling that 1 bank is so lean
i did swap injectors from side that is running poorly to the side that is operating properly, so i know that clogged injectors is not an issue
i dont have a problem doing a road test and recording data , but shouldnt i be able to see changes at idle, i can see data that suggests that it is running lean and trying to add fuel even at idle
any help is appreciated thanks ed
7 years 2 months ago #33045 by simclardy
I think the point of the road test is to see the engine response under different loads and rpms, but Andy knows more than me and knows better what be wants to see.
On the vacuum gauge is the needle steady? When you snap the throttle what is the low and high numbers? At steady high rpms what is vacuum and is it steady?
I agree that something common to the bad bank is the culprit. A breathing problem on one side, a bad ground that is common to say injectors on one side, a pcm on one side.
Look forward to you finding the solution, and the path that leads you to it. Cheers
Sandy
  • ed begley
7 years 2 months ago #33051 by ed begley
i will perform those vacuum gauge tests when i get home from work today
i look foward to seeing what PIDs Andy wants me to monitor
7 years 2 months ago #33053 by Andy_
One thing I wouldn't mind seeing you try that is quick and easy, is trying to drive to O2 sensors rich with propane. It can be done at idle. Just take a propane bottle of some type and feed some propane into the engine. The oxygen sensors should all go rich. Is this something you can try?
  • ed begley
7 years 2 months ago #33054 by ed begley
i can do this , although i am not be able to get to it before friday.
would i introduce propane through the intake before the maf sensor by removing air box lid
7 years 2 months ago #33055 by Andy_
You can do the test like that. If the sensors on both banks go high, we'll move on.
  • ed begley
7 years 2 months ago #33056 by ed begley
ok thanks
like i said i may not be able to get back to untll friday due to my work schedule
thanks for your help
7 years 2 months ago #33063 by simclardy
Andy is there a risk of explosion if the MAF has a hot wire element? I don't mess with cars for a living but i am a licensed gas fitter and electrician. I know enough to be scared of both. Lol
  • ed begley
7 years 2 months ago #33099 by ed begley
ok iwas ready to perform your propane test , but i decided let me check aprk plugs one more time so removed all plugs checked gaps checked for cracked insulators etc all looked good, then i decided to check spark ,using a spark tester i found that i have no spark on any cylinder on the left bank. I was so sure it was going to be something cmputer related i overlooked the basics. Now as they say when it ran it pours , i discharged my battery when cranking and testing each cylinder with a test light , no problem i will just get my battery charger and charge it up, battery charger not working.So i am off to get a charger so i can begin diagnostics, Any insight would be greatly appreciated i am assuming it has to be something common to left bank poor connection bad ground etc, this being a 2008 i am sure someomne has run into this scenario before, Anyway off to get a charger
thanks ed
  • ed begley
7 years 2 months ago #33103 by ed begley
Well got a new charger , charged battery and begin testing
Since all cylinders are not firing on bank 1 (confirmed with spark tester works on bank 2 not working on bank 1).I found something on line on how to test gm cop coils, i performed this test at the main coil harness not esch individual coil ,
pink wire should be 10-12volts......12v ok
black wire ground should be 10-12volts.......12v ok
brown wire low refrence signal...........should be 10-12 volts ...12v ok
green wire trigger wire should read 5-8 hertz i got no reading on this wire
thqt being said i checked continuity between pcm and this grn wire , wire actually changed color to red/wht in harness it went to #20 in pcm connector 1 and i had continuity.
At this time i assumed that i had an issue with the pcm
I thought where does the grn wire on bank 2 go so i checked continuity from there expecting it to possible go to connector 2 however it actually had coninuity to the same terminal #20 connector 1 as bank 1 , i tried the same test on on the grn wire looking for 5-8 hertz again i got no such reading . I thought what if a ran jumper from bank 2 grn wire to grn wire bank 1 maybe they bwould all start working, when i did this the eng just shook and misfired more.
at this time i thought what is swapped the entire coil assy all 4 from one side to the other , coils from bank 1 that were inop are now working properly and coils from bank 2 that were working are now inop.
I am a little confused sine both grn wire go to the same terminal at the pcm connector, i dont know if there is another way to determine the trigger signal other than a hertz reading as this test was inconclusive
the chart that i found for pcm breakout ..says battery positive voltage
i was unable to read any voltage at this terminal grn wire at either bank yet bank 2 is working
even tried a cop coil tester ( looks like a mini fly swater) you just hold it on coil and it will light up on a working coil lights up on bank 2 not on bank 1
i would be happy to try any other tests or if anyone ahs a link to wiring harnes diagrams
7 years 2 months ago #33107 by simclardy
Why do you say the black wire/ground should have 12v? Sounds like a bad ground.
  • ed begley
7 years 2 months ago #33111 by ed begley
the instructions that i was following described the proceedure to test these circuits, i thought the same thing the first time i did the test i used a test light hooked up to battery pos , so the the light illuminated when i probed the black wire , so considering how the test light is hooked up , the black wire is a ground, the instructions were to hook the dvom red lead to pos and the the blk lead to the black wire , doing it this way it does read 10-12v i guess it makes sense
what i dont understand is why the bank 1 and 2 seem to have the same readings
the instructions called for a reading in hertz on the trigger wire , i did not get a good reading on this circuit which is why i still have a problem,
what also dont understand is that the grm/wht wire on the bank 2 and the grn wire on bank 1 have continuty to the same pin on the pcm connector, on top of that when i check continuity from grn/wht to grn wire Using the (beep function) i get no beep but i do get resistance reading of 1875 ohms
i know i am close but i am missing something on bank 1
here is the link to cop diagnostics
easyautodiagnostics.com/gm/4.8L-5.3L-6.0...test-the-cop-coils-2
7 years 2 months ago - 7 years 2 months ago #33115 by simclardy
Ok i read the test. Now the 12v on ground make sense. The only thing i would prefer is using an incandescent test light on ground (black wire) and feed wire. This will load the circuit and be a better test. Just be careful to not load the computer module. The high current could fry the pcm.
As for the hz test. What kind of meter do you have? Try it in a wall outlet if you feel comfortable doing so and you should get 60hz. Make sure the meter can go down to 5hz. Some meters don't have the range.
A wiring diagram would answer the question on the signal wire being shared. An ohm test to signal just measures the component resistance, and i don't think it's helpful.
I would expect each coil to have a dedicated signal wire? Unless it is some type of data cable. Doubt it.
Your are almost at the end!
Last edit: 7 years 2 months ago by simclardy.
  • ed begley
7 years 2 months ago #33116 by ed begley
the test light i am using is older and uses a small bulb not and led , i did all tests with the test light and then again with the meter
the dvom i am using only has a scale of 20hz
i am searching for a good wiring diagram
at least i know its not the coils since i swapped them
i just dont want to guesss at a pcm
thanks
7 years 2 months ago #33122 by simclardy
I just looked at a diagram here
2008_LD_ElectricalPickupsChassisCabs.pdf
The power wire are common to each other, as are the ground, and reference. The signal/ trigger should be dedicated back to the pcm. If you have an 8 cylinder you should have 8 trigger wires.
Im not sure if i had the right diagram, but that is what i expected.
7 years 2 months ago #33134 by simclardy
Is it 20hz max or min?
You should be able to check voltage in ac mode and get a reading. You could compare good to bad. I thought a noid light or led test light might be a good visual. I would not put a heavy load on the pcm with the incandescent light.
