2001 Buick Century occasionally stumbles, more rarely dies.
- DaveDay
I am new to ScannerDanner world and I am definitely not a technician by any stretch (though I wanna be! DIY in the driveway type.) The vacuum at the fuel regulator is 17 in Hg and it regularly pulses low to 16.5. I notice that when I have a scanner connected and I am watching the O2S, when I accelerate to ~4000rpm the voltage of the O2 sensor suddenly collapses to near 0V and stays there until the rpms fall some or until I lift off the gas. If I don't lift off the gas the engine rpms rise and fall in a regular fashion, first 4K then 3.5K etc. When the rpms are high the O2S voltage is near 0.
Please excuse the ignorance here, I am literally only on Chapter 1 of Mr. Danner's book, and though I have done a lot of mechanical DIY repairs over the years, I am over my head here for the time being.
I have not even looked at the spark plugs/wires etc yet.
Any guidance will be appreciated. I do not have a scope yet and have only a Blue Driver ODB2 thingy and an old Genysis OTC SPX scan tool. I do have the usual DVM and a Power Probe and a garage full of mechanical tools etc. I have mostly been a parts changer.
Thanks,
Dave Day
DaveDay wrote: I notice that when I have a scanner connected and I am watching the O2S, when I accelerate to ~4000rpm the voltage of the O2 sensor suddenly collapses to near 0V and stays there until the rpms fall some or until I lift off the gas.
It sounds like a fuel delivery problem. All O2 sensors should go full RICH and WOT. What is your fuel pressure at idle, and during a WOT acceleration.
Are you in Park, or Neutral, when you are doing this. If so, that is the rev limiter preventing OVER revving. It is better to do a test drive and wrap out 1st, or 2nd gear, while watching your O2 sensors...they should go full RICH.
When exactly does it happen? During acceleration, coming to a stop, idling?
Besides the stumble/stall, does the engine run well?
Does this happen while stopped in park, or driving down the road? :huh: Because it kinda sounds like you're describing the rev limiter.
Those will work just fine.
- DaveDay
I am just in park in the driveway. I'll test drive it and get back to you.
I haven't checked the fuel pressure yet, I'll do that tomorrow. I did change the fuel filter.
Dave
Tyler wrote: CHAD GET OUT OF MY HEAD.
I will take that compliment.
