Orifice
  • CGIRL1373
  • CGIRL1373's Avatar Topic Author
7 years 1 month ago #33598 by CGIRL1373
Orifice was created by CGIRL1373
Can someone tell me where the orifice is located for the a/c on a 2010 Ford F-150 Lariat 5.4 engine.
7 years 1 month ago - 7 years 1 month ago #33603 by Chad
Replied by Chad on topic Orifice
It will be in the line that goes between the Condenser and the Evaporator. There is, usually, a couple dents, or indentures, in the line and a big Union Nut where you can take the line apart. I have seen some, though, that do not come apart. You have to replace a whole line segment. If your AC works, you can FEEL the line. The orifice tube is where the line goes from hot, to cold.
If your vehicle is equipped with a Thermal Expansion Valve (TXV), it won't have an Orifice Tube.
Last edit: 7 years 1 month ago by Chad.
7 years 1 month ago #33610 by gav09
Replied by gav09 on topic Orifice
That vehicle doesn't have an orifice tube. It uses an expansion valve.
