toyota avensis 2003 p0121
  • cyrus.nk
  • cyrus.nk's Avatar Topic Author
9 years 10 months ago - 9 years 10 months ago #4406 by cyrus.nk
toyota avensis 2003 p0121 was created by cyrus.nk
Fault code p0121.the car has drive by wire throttle.6 wires and have check all looks fine.changed throttle no change.anyone has wiring diagram for throttle pleas?
Last edit: 9 years 10 months ago by cyrus.nk.
9 years 10 months ago #4407 by matt.white
Replied by matt.white on topic toyota avensis 2003 p0121
Our local Avensis are all cable so I can't offer a diagram sorry. Just looking on iATN the main complaint was there's different throttle bodies listed between Cali and federal emission laws and they're interchangeable physically but won't work if fitted incorrectly. Hope this helps
  • cyrus.nk
9 years 10 months ago #4462 by cyrus.nk
Replied by cyrus.nk on topic toyota avensis 2003 p0121
Yes thanks
9 years 10 months ago #4476 by rccharlton
Replied by rccharlton on topic toyota avensis 2003 p0121
Well I just worked on a Pontiac Vibe and its a Toyota hiding under the Pontiac badge.
Wire 1 & 2 was for the Motor
Wire 3 ground black wire
Wire 4 sensor circuit B Green wire
Wire 5 was 5v reference
Wire 6 sensor circuit A Green wire
Wire 4 and 6. one is circuit A and the other is Circuit B. The ECM looks at the voltage difference to set the P0121 code.
If A is above B by more then 1.6v it will set.
If A is below B by .8v it will set
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 10 months ago #4477 by Dylan
Replied by Dylan on topic toyota avensis 2003 p0121
First you say you've checked all 6 wires 'and all looks fine'.... Then you change the throttle body, no result, and now you ask for a wiring diagram. Shouldn't you have started with this?
Also, your posts always lack critical information. We've asked you several times to be more specific about the vehicle you're working on. 'Avensis 2003....'?? Don't wanna be the bad guy here but you just ignore 'suggestions' Cyrus...
  • cyrus.nk
9 years 10 months ago #4551 by cyrus.nk
Oh ma friend DYLAN am sorry for tis pleas.i promise next time i will try as much as possible to be more specific.now i fixed the car and the problem was that the throttle wich some mec b me changed was not for that car and also there was no power feed to the computer for throttlecontrol.WISHING U A HAPPY NEW YEAR!
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 10 months ago #4569 by Dylan
Ok thank you Cyrus. I also wish you a happy New Year!
