2011 Jeep grand Cherpkee / 3.6 charging issue
  • jsampson
  • jsampson's Avatar Topic Author
7 years 1 month ago #33981 by jsampson
I have a 11 Jeep with a 3.6. why wife smelled burning Friday on the way home. She got home I didnt smell anything and no lights on on the dash. The belt and tensioner are fine. I checked voltage at the alternator and is was battery voltage. removed the alternator and had it tested, it failed the test. Bought a new alternator and had it tested before installing it. Still having the same issue. How do I test the 2 wires that go to the ECm that controle the alternator. I have heard that Jeepshave a issue with the diod failing and destroying the ECM..
7 years 1 month ago #33984 by Cheryl
You have a scanner that can read live data? Should be able to see voltage sense and generator duty cycle and codes. Got power at the big battery wire at the alternator??
7 years 1 month ago #33985 by gav09
The 2 wires one will be a power and the other pulsed to ground by the engine computer. The last one I worked on that had a bad alternator also burned out the PCM. There was a recall for this condition so it went to the dealer.
