2006 Chevrolet Truck Colorado 4WD 3.5L engine stalls or dies
- BetterCallBrody
- Thank you received: 2
7 years 1 month ago #34042
by BetterCallBrody
2006 Chevrolet Truck Colorado 4WD 3.5L engine stalls or dies was created by BetterCallBrody
I think if the resistance was too high it would throw a code for that circuit?
- John Curtis
- Thank you received: 111
7 years 4 weeks ago #34060
by John Curtis
Replied by John Curtis on topic 2006 Chevrolet Truck Colorado 4WD 3.5L engine stalls or dies
How long has the vehicle had the misfire?
If it were a bad coil it would most likely be cylinder specific.
Does the stall happen only when the engine is hot? And when it does will the vehicle start and run?
Do you have live data or a fuel pressure gauge? I’d start with fuel delivery.
- juergen.scholl
- Active partschanger
- Thank you received: 462
7 years 4 weeks ago #34065
by juergen.scholl
Replied by juergen.scholl on topic 2006 Chevrolet Truck Colorado 4WD 3.5L engine stalls or dies
A single cylinder misfire is not likely to make the engine stall.....
Could you share the freeze frame data and elaborate on the conditions when the engine actually stalls, please? Do you know what goes missing when stalling( do you suspect spark and hence the original question?)
Will it restart easily?
- autojoe
- Thank you received: 7
7 years 4 weeks ago #34066
by autojoe
Replied by autojoe on topic 2006 Chevrolet Truck Colorado 4WD 3.5L engine stalls or dies
Gm has tsb relating to carbon buildup on valves. Get some techtron total fuel system cleaner put in 1/2 tank. Also works well on injectors.pull and check plugs. Carbon would cause high compression and lean condition. If you had a scan tool to monitor your fuel trims under load.
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
7 years 2 weeks ago #34427
by VegasJAK
Replied by VegasJAK on topic 2006 Chevrolet Truck Colorado 4WD 3.5L engine stalls or dies
P0455 is an EVAP code for a large EVAP leak. the P0300 random misfire can be related to the EVAP problem. the stalling problem is a symptom of an EVAP leak as well. a purge solenoid opening can stall the engine. I would resolve the EVAP problem first.
- VegasJAK
7 years 1 week ago #34532
by VegasJAK
What are the STFT/LTFT and 02 readings. Are you still getting P0455 and P0300.
