2012 jeep compass c1020 2wd
- tim.smith1
- Thank you received: 61
7 years 2 weeks ago #34455
by tim.smith1
2012 jeep compass c1020 2wd was created by tim.smith1
truck came in with code c1020 tested for 12volts at sensor using sensor ground it was good checked signal at sensor compared to right rear it was clearly not right so we replaced sensor now the right rear and left rear sensors produce the same waveform spinning them by hand but the code will not clear and when you drive it the left rear sensor shows 0 mph also i tried to disconnect the battery and do a hard reset....................i have not checked powers and grounds to the abs module but is there anything i could be missing............i also checked both wires at the abs module for the left rear sensor and they look good
- Cheryl
- Thank you received: 215
7 years 2 weeks ago #34461
by Cheryl
Replied by Cheryl on topic 2012 jeep compass c1020 2wd
Try a module reset with scanner?? Also scope signal at abs module on both wheels for comparison?
The following user(s) said Thank You: tim.smith1
- Cheryl
7 years 2 weeks ago #34462
by Cheryl
Any tsb?
- tim.smith1
7 years 2 weeks ago #34465
by tim.smith1
Replied by tim.smith1 on topic 2012 jeep compass c1020 2wd
Not sure what you mean by module reset I have a snap on versus and a Solus edge don't see that option please any help on finding that..........I can scope the right rear sensor at module but I did both of them at the sensors and they look just like the left rear at the module ........don't see any tsb ...........thanks Cheryl for your help
- tim.smith1
7 years 1 week ago #34484
by tim.smith1
Okay guys this truck was troubling but I figured it out and I believe that all the test I did was all the confirmation I needed to call the abs module but as all of you know that is a hard call so I did one last test at the abs module plug I took the two wires from the left rear sensor and swapped them with the right rear sensor wires ................after the switch the code stayed the same but of course in the data stream now the right side was not working and the left was so somewhere in the abs module there is a problem the customer is not fixing it now however he said that he will have us repair it in the future I will update this post if he does but I can't guarantee this will happen .............closing I am 100 percent certain this car needed a left rear wheel speed sensor and an abs module. Thanks to all that helped I sure hope this helps someone.
- Cheryl
7 years 1 week ago #34518
by Cheryl
Sorry I’m used to witech. Well glad ya updated us so 2 problems for one light
- tim.smith1
6 years 11 months ago #34992
by tim.smith1
Customer came back in we replaced the module and we no longer have a light and the sensor is now reading as it should
