1995 Sonoma OBDI or OBDII or what?
  • dennis524
  • dennis524's Avatar Topic Author
7 years 5 days ago #34672 by dennis524
1995 Sonoma OBDI or OBDII or what? was created by dennis524
My Neighbor has a 1995 GMC Sonoma with a 2.2L engine.
His check engine light came on when the engine started running really
rough and finally stopped running. Engine would try to start and then die.
The DLC is the OBDll style. When I connected my scan tool it said that it could not
connect to the vehicle. I looked at the pins in the DLC and there were only 4 pins.
Does anybody know what kind of diagnostic system is in this truck and what do I need to be
able to get to the PID's and the trouble codes?
Turned out the truck had a bad fuel pump.
Thanks for any help.
Dennis
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
7 years 4 days ago #34681 by VegasJAK
Replied by VegasJAK on topic 1995 Sonoma OBDI or OBDII or what?
the OBDII software that you're using came out in 1996. OBDI was from 1991 - 1995. An adapter is available to be able to scan an OBDI system with a OBDII scanner. OBDI was mostly for emissions control related diagnosis.
  • dennis524
7 years 4 days ago #34685 by dennis524
Replied by dennis524 on topic 1995 Sonoma OBDI or OBDII or what?
Thanks for your reply.
OBDII has a 16 pin DLC and OBDI has 8 pins correct me if I'm wrong.
If you look inside the DLC it only has 4 pins and has the shape of an OBDII DLC.
If I can get an adaptor will I be able to get any PID's or just the trouble codes?
Thanks again,
Dennis
7 years 3 days ago #34690 by Noah
Replied by Noah on topic 1995 Sonoma OBDI or OBDII or what?
Not all the pins are used in the dlc connector. A better description of it would be a 16 cavity connector.
The following user(s) said Thank You: Chad, dennis524
