2004 Kia Sedona 3.5L Timing belt replacement
  • joshuamal
  • joshuamal's Avatar Topic Author
6 years 11 months ago #35021 by joshuamal
All,
I’m needing a timing belt diagram for this vehicle, Kia Sedona 3.5L. I’m replacing the crank sensor due to fault and noticed the belt with cracks on it. It seems a little difficult for replacement, any inputs on the replacement and procedures along with a belt diagram or layout would be great to have.
Also, while searching information for the removal of crank sensor, found some comments of people having issues with the harmonic balancer pulley boot being a problem of breaking off. I already removed it but will need this layout information along with the torque spec on the crank pulley bolt (harmonic balancer) center bolt.
Any other inputs with this job or procedures from past experience are welcome.
Thanks
Josh
6 years 11 months ago #35036 by gav09
Buy a DIY of Mitchell or alldata for replacement instructions. don't reuse the crank bolt. get the new updated bolt and washer from KIA
6 years 11 months ago #35042 by Chad
File Attachment:
File Name: Kia3.5TimingBelt.pdf
File Size:132 KB
135 ft lbs, on Crank bolt
  • joshuamal
6 years 11 months ago #35048 by joshuamal
Replied by joshuamal on topic 2004 Kia Sedona 3.5L Timing belt replacement
Thanks Chad for that diagram and spec, that surely will help a lot.
Gav09 thanks for the replacement advise.
6 years 11 months ago #35052 by Tyler
I agree with gav09 about the crank bolt. The Sorento's of the same year had problems with the bolt breaking off in the crankshaft after someone reused it. Kia has a TSB about it, though it doesn't apply to the Sedona. I'd replace the bolt anyway. ;)
Be sure to replace the hydraulic tensioner as well, if your belt kit didn't come with one. These belts will take any excuse to jump time. Too long a belt and too many pulleys/sprockets, IMO.
Time to create page: 0.265 seconds
