04 tahoe 5.3 4l60e vss sensor ?
  • Tonymac
  • Tonymac's Avatar Topic Author
6 years 11 months ago #35038 by Tonymac
04 tahoe 5.3 4l60e vss sensor ? was created by Tonymac
Hello I was wondering what should the vss read on live datastream mind is around 800 when the mph is 40 i have older snap on
6 years 11 months ago #35041 by Cheryl
Replied by Cheryl on topic 04 tahoe 5.3 4l60e vss sensor ?
Vss should read vehicle speed. So at 40 miles per hour it should read 40 miles per hour. Is there a code or issue your having
  • Tonymac
6 years 11 months ago #35044 by Tonymac
Replied by Tonymac on topic 04 tahoe 5.3 4l60e vss sensor ?
Thanks for the reply . Have no codes but transmission has shift issue 2-3 and 3-4 flare ups then goes to limp mode not sure where to strart trans was rebuilt a year or two ago
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
6 years 11 months ago #35082 by VegasJAK
Replied by VegasJAK on topic 04 tahoe 5.3 4l60e vss sensor ?
Check the TCMB fuse in the main fuse box located under the hood. It's a 10a fuse. If blown it will cause you vehicle to go into limp mode. If blown, look for a short.
Your error code is the 4L60E.
