Secondary Air Injection Pump
  • RadMan049
  • RadMan049's Avatar Topic Author
6 years 11 months ago #35343 by RadMan049
Secondary Air Injection Pump was created by RadMan049
2000 GMC Z71 4X4 SLT 5.3. I'm getting the code P0410. I replaced both secondary check valves because one of them wasn't closing all the way. (leaking) I noticed in your video when you applied power to the air injection pump from an outside source, the pump ran continually. When I do the same to my air pump, it will run for about two seconds then quit. Is this a sign that my pump is bad. I checked everything else. I can also disconnect the air pump and hook up a volt ohm meter to pump power connecter and it shows a constant 12 volts but, when connected the pump it doesn't run.. According to my manual the pump is supposed to run 4 minutes max after vehicle is started and the ECM will shut off the power source.. Help will be greatly appreciated. Thanks!
6 years 11 months ago #35363 by Matts Auto
Replied by Matts Auto on topic Secondary Air Injection Pump
Do you have a scan tool with bi-directional control capability? If so you should be able to command air pump on n off with scan tool. While commanded on it should run continuously until commanded off. Water intrusion is the main reason for secondary air system faults. Pull the larger diameter hose off pump and see if water runs out of pump/hose. Sounds like water may be stopping pump operation. I would suggest removing hose first before powering pump back on. (Maybe too late).
