2010 Cadillac CTS - Battery Reset
- robert.lesaca
- Thank you received: 19
6 years 11 months ago #35361
by robert.lesaca
2010 Cadillac CTS - Battery Reset was created by robert.lesaca
Though my scanner has a battery reset, unfortunatelys it does not support one for Cadillac or any GM model. Is there another way of resetting battery after a replacement was done? The cars starting fine exept the headlamps and signal lights dont work after battery replacemen; there are no other issues nor DTC...thank you.
- robert.lesaca
6 years 11 months ago #35425
by robert.lesaca
Replied by robert.lesaca on topic 2010 Cadillac CTS - Battery Reset
Ok...I decided to check the BCM module; connected the CAN Hi and Lo to my laptop and this is the waveform with BCM X3 connector pluggedin :
And this the wavform with the connector X3 unplugged :
Like wise the terminating resistor read 62 ohms with X3 connector unplug and 122.7 plugged in.
I am not versed in CAN Bus. But does the waveform indicate short to ground in the CAN Lo? I checked power to all connectors and all read battery voltage. It was only the ground wire in connextor X3 that read 29.6 mv KOEO and 31.4 mv KOER. In the absence of a wiring diagram, I cannot trace wires thats connected to connector X3.
I hope someone out there can share his thoughts or expertise. I want to make sure if its a component or module that is defective. Thanks
- Cheryl
- Thank you received: 215
6 years 11 months ago #35426
by Cheryl
Replied by Cheryl on topic 2010 Cadillac CTS - Battery Reset
In reality they both look wrong. You are supposed to see 2.5 yo 3.5 volts on can h and 2.5 to 1.5 can l. You sure you have a good scope ground?? If they looked like that then I’d suspect a no communication with the bus.
- robert.lesaca
6 years 11 months ago #35427
by robert.lesaca
totally agree...yes ground is good, connected in BOB chassis ground.
- Cheryl
6 years 11 months ago #35428
by Cheryl
What’s it look like at another module or even at the data link connector?
- robert.lesaca
6 years 11 months ago #35433
by robert.lesaca
I have tried other modules yet...I just finishede checking the integrated power/fuse and relay box and noticed that the two bolts holding the main connectors was loose, hmmm just wondering if can be a cause
- robert.lesaca
6 years 10 months ago #35907
by robert.lesaca
Sorry for the delayed followup...
The owner couldnt wait any longer and believes that it is the BCM that is faulty. Despite my telling him my intial tests showed otherwise, he took the car and bought a new BCM. A week later he called to ask if I can look at it again as the problem did not go away. This time I had to refuse and advise him to bring it to another shop instead.
