No injector pulse to number two cylinder
- Farro31
6 years 10 months ago #36024
by Farro31
2013 honda civic ex-l.....1.8L.....
I have a Christmas tree of lights, abs, power steering, vsa, check emissions blah blah blah lol. Anyways I'm not getting injector pulse to the number two cylinder. I started out with codes P0202 and P0302. So I ohm the injector in cylinder two and the injector was fried reading way over 10ohms, replaced injector of course and then noid lighted the circuit, NO PULSE! I checked the wire from the connector to the pcm for continuity and got the beeping, so wire is good, I guess lol. Then I plugged it back in and fired up the car to back probe the pcm, No pulse at the pcm....so I sent the pcm into a repair shop and they said it had a software failure and they reprogrammed it. Said all circuits checked out ok. I get it back and plug it in, and imagine that nothing's changed, all the same problems.....So back story I'm RUSTY! I was a tech at a chevy dealership for a few years 2000to2004 and then joined the Infantry and went to war...So im basically stuck and need some help from some sharp minds. I would really appreciate it. Thank you very much
No injector pulse to number two cylinder was created by Farro31
- John Curtis
- Thank you received: 111
6 years 10 months ago #36031
by John Curtis
Replied by John Curtis on topic No injector pulse to number two cylinder
How long is the engine running before you check for injector pulse? Sometimes the ecm will shut down the injector if the cylinder is misfiring. If it isn’t intentional shutdown and the injector isn’t pulsing then you need to check for pulse right at the ecm. If it isn’t there then it needs an ECM.
- cj1
- Thank you received: 12
6 years 10 months ago #36037
by cj1
Replied by cj1 on topic No injector pulse to number two cylinder
"replaced injector of course and then noid lighted the circuit, NO PULSE!"
The noid shouldn't light until circuit complete thru the PCM.
Verify that injector wire to PCM isn't grounded.
- Cheryl
- Thank you received: 215
6 years 10 months ago #36040
by Cheryl
Replied by Cheryl on topic No injector pulse to number two cylinder
Do you have power to the injector? Maybe it’s not a control issue but a power feed problem to the injector. Broken wire?
- Cheryl
6 years 10 months ago #36041
by Cheryl
The power feed wire will be the same color for all 4 injectors
- washer
- Thank you received: 13
6 years 10 months ago #36164
by washer
Replied by washer on topic No injector pulse to number two cylinder
First, thank you for your service.
Second, can you provide a wiring digram for this vehicle?
- Billsgarage
6 years 10 months ago #36181
by Billsgarage
Replied by Billsgarage on topic No injector pulse to number two cylinder
Have all the "lights" come on at the same time as this problem? My first thought was a bad ground.
