1997 Nissan Pick up 2WD 2.4L Clutch hydraulic issue
- joshuamal
- Thank you received: 3
6 years 10 months ago #36081
by joshuamal
1997 Nissan Pick up 2WD 2.4L Clutch hydraulic issue was created by joshuamal
All, I’m working on this 1997 Nissan pick up truck and there’s an issue with the clutch hydraulics trying to get to build pressure. After replacing the fluid as it was too nasty an adding the new fluid it has lost the pressure. I have bled the master at the vehicle and at slave drive but the pedal pressure doesn’t build up as it stays down. Before the Procedure the pressure was fine and vehicle normal until replacing the fluid. Never had this problem before .
After doing some research, there’s a dampening valve with a bleeding port, I have not attempted to bleed from it but have seen other people online eliminating this device. Should I try to bleed from it and eliminate it ? At last I did ordered a new master and slave drive in case both are bad. Any inputs or ideas are welcome.
Thanks and merry Christmas.
6 years 10 months ago #36091
Replied by Andy.MacFadyen on topic 1997 Nissan Pick up 2WD 2.4L Clutch hydraulic issue
Sometimes bleeding a well used master cylinder by pumping the pedal can cause the seals to fold over.
To test a mastercylinder Remove the pipe union at the mastercylinder and replace it with a bleed nipple and bleed it if the pedal is solid the master cylunder is good.
These days I always use a top down pressure bleeded to bleed both brakes and clutches it saves a huge amount of time. Pressure bleed tools are available at prices to suit both DIY and frequent pro workshop use.
- joshuamal
6 years 10 months ago #36101
by joshuamal
Replied by joshuamal on topic 1997 Nissan Pick up 2WD 2.4L Clutch hydraulic issue
Andy or anyone,
I’ll try that suggestion on the master cylinder. I have come across videos online and articles about eliminating the clutch damper valve, what is your opinion?
Also I never had an issue with bleeding brakes before as I been using a plastic bottle and hose submerged with fluid. Now, I did tried bleeding the damper valve after my post using my bleeding method but didn’t do anything which I also used on the slave drive pumping the pedal several times with the hose on it as I do the brakes. Basically I open the valve and pump pedal perhaps 20 times with the bottle connected to it and still didn’t have a pedal. Is there something I’m doing wrong?
What is this top and down pressure bleeding tool and where you get it from? Also, I have not try a vacuum pump yet, will that work?
Anyone any inputs are welcome. Thanks in advance.
- Tutti57
- Thank you received: 254
6 years 10 months ago #36235
by Tutti57
Replied by Tutti57 on topic Re:1997 Nissan Pick up 2WD 2.4L Clutch hydraulic issue
I saw something similar to this where the tech thought the reservoir was full, but there was a separate back chamber that went to the clutch and it was hard to see that it wasn't full. As soon as we got the whole thing filled up with fluid it bled fine. Are you getting any fluid out at all?
Nissan Technician
Nissan Technician
- joshuamal
6 years 10 months ago #36237
by joshuamal
Replied by joshuamal on topic Re:1997 Nissan Pick up 2WD 2.4L Clutch hydraulic issue
Thanks for your input, already took care of it. It did take about two hours to bleed system manually.
