Will only start for 3-4 seconds with Cam Sensors Unplugged
- darcy.mcintosh
I can sometimes get a stumble upon trying to start it but it dies. I only get one injector pulse upon first crank. Unless I unplug the cam position sensors and then I will get a fairly consistent injector pulses and it will fire up for 3-4 secs and die. Fuel pressure stays constant on the fuel regulator and fuel is present at rails. Sometimes I do here the coils continuing to fire after I release the key until I hit the key again and then it will stop. Only code I got was P0690, only with a hand hald reader but not with HP Tuners(no codes at all). I have confirmed wiring is good in on and run. Battery voltage is constant while key is cranking and when released when it fires up. Voltage maybe drops .5V when cranking and is in a good range.
I'm thinking my PCM is bad but am unsure and am hesitant to spend $500 on that unless I know for sure. My first question is why would it fire with the cam sensors unplugged? Any insight or help would be appreciated.
My set up is as follows.
All stock engine, all sensors are stock.
Manual transmission.
Stand alone fuel system with in tank pump and manual fuel pressure regulator.
Return style fuel system.
Fuel pressure set to 42psi.
I have 12V at coils in key on
I have 12V to injectors with key on.
New Ford injectors
New Spark Plugs.
New Coils.
New Cranks Sensor.
New Cam Position Sensors.
New MAF Sensor.
I have 5V reference at sensors.
I have confirmed wiring is correct at pins and have no shorts to ground.
I have confirmed good grounds.
D
- Cheryl
- Thank you received: 215
- Cheryl
- Desmond6004
Read more at: www.obd-codes.com/p0690
Copyright OBD-Codes.com"
- Desmond6004
This almost makes it sound like a CAM timing issue, if it starts with the Cam sensor unplugged.darcy.mcintosh wrote: . I only get one injector pulse upon first crank. Unless I unplug the cam position sensors and then I will get a fairly consistent injector pulses and it will fire up for 3-4 secs and die.
- washer
- Thank you received: 13
- Cheryl
- darcy.mcintosh
Cheryl wrote: Did this engine run before the swap? Have you did anything mechanical to the engine?
I have never heard it run but was told it only has 15,000km on it as they swapped in a 5.4L shelby engine and this car was only limited to summer use.
I had my mechanic friend come over and this is what we have found
1) We have no RPM while cranking,
2) We have no Cam and Crank synchronization,/correlation
3) The fuel system has been tuned with HP to be a return style and stand alone no controlled by the PCM, but the scan tool shows a fuel pump fault.
4) We have 60ohms resistance on the can bus is that correct?
5) we measure 2.5V from each canbus data line to ground. Is this correct?
Thanks Darcy
- Desmond6004
yesdarcy.mcintosh wrote: 4) We have 60ohms resistance on the can bus is that correct?
darcy.mcintosh wrote: 1) We have no RPM while cranking,
I'd pursue this first, as it definitely points to some kind of cam/crank signal issue.
Sounds like the PCM software is still looking for communication with the FPDM? :huh: That by itself shouldn't cause your issue, as far as I'm aware.
Love it.
Did the CKP/CMP sensor wiring get changed during the swap? I've seen CKP connectors replaced due to harness damage and get the two pins swapped in the process. This causes the signal to get inverted, and the PCM can't use it. :silly: Just a thought.
A scope capture of your CKP and CMP would be best. IF you don't have one available, you can at least use a DVOM to check signal amplitude of both during cranking. Set your DVOM to AC volts and connect it across both CKP or CMP wires at the PCM. Crank it and note your highest reading. I don't have a spec on hand, but I'd expect 500mV or better. Zero is a problem.
- darcy.mcintosh
Love it.
This is a possibility. One thing I did notice is that sometimes when trying to start it and you stop turning it over and leave the key in the on position that you can hear the coils continue to fire. If you turn the key off or hit the key again to turn it over the condition changes.
When I back probed the CKP I only got 180mV which is low. Do you think or know if the CKP is polarity sensitive?
D
- juergen.scholl
- Active partschanger
- Thank you received: 462
- darcy.mcintosh
juergen.scholl wrote: Yes, on Fords with VR crank sensors polarity matters. Get a diagram to make sure the wires are not inverted. 180 mV would be too low of a signal if this was peak to peak between the 2 wires.
I double checked polarity and we are good. I disconnected my CKP and connected my alligator clips and my DMM and I actually have 900mVAC while cranking, so that is good.
If I don't have an rpm signal and no cam crank correlation/synchronization, and I have also tested continuity and pinned out my cam and crank sensors wires to the PCM Harness as well as tested ohms for shorts to ground and all is good. It would almost suggest that bad PCM as it's no using the crank signal to do what it needs to.
D
