2007 Silverado P0300
  • Jasonpsapp17
  • Jasonpsapp17's Avatar Topic Author
6 years 10 months ago - 6 years 10 months ago #36127 by Jasonpsapp17
2007 Silverado P0300 was created by Jasonpsapp17
New body style 5.3 AFM
Any advice would be much appreciated! My brother's truck needs to pass CA smog as soon as possible and this one is now kicking my butt. Newbie here but i'm feeling good about the checks I've done. I also have access to a Snap On Solus Edge at the moment so I want to learn and knock this out efficiently. It has had a P0300 misfire issue for sometime probably close to 2 years, combined with a Service Traction control and Stabilitrak light that comes on and off. The last time it was smogged by a shop that did not solve the misfire and now it's that time again. I've just got back home to help him out a bit as much as I can.
Some symptoms:
-P0300 Miss on cylinder 3 mostly with half as many on 8 according to the data. Rough idle but runs fairly smooth and strong
-When the service stabilitrak light is on there's the rough 1-2 shift and clunky engagement when shifting into gears.
-At some point in the last year he had received the reduced power message while on the freeway
Here's a list of things recently done:
-New battery, old one tested bad
-Replaced battery ground cable (2016) due to wonky electric locks/ground issue
-Swapped coil 3+8 with non misfiring cylinders=No change
-Newer Iridium(.040) plugs + AC Delco wires which test fine. Also swapped after the coils=No change
-Cleaned MAF and reinstalled stock air intake. Had Airraid carb compliant intake. Still has oiled filter though..
-Verified MAP sensor voltages with vacuum applied
-Checked fuel pressure, 20-Key on 60-start up and 48-running
-Injector balance test showed all injectors almost exactly the same except for Injector 1? I will double check but I believe it was something like 4-5 psi off
-Ran some seafoam through the brake booster and techron fuel cleaner in the tank now
-Secured better the PCV hose that was broken/fixed
-Tightened loose driver side exhaust manifold
-Sprayed around intake looking for leaks=No change
One thing I am a little suspect of is the 02 B2S2 operation. I may not be understanding completely yet although I'm still studying up. B1S2 shows fluctuating voltage from 80-850 where as B2S2 was stuck in the 700s at that time. Truck is cold now so any verifications can easily be looked at. I can post anything off of this Solus Edge or videos that are needed.
I'd appreciate any help! Thanks for reading. I may have missed something but let me know, I'll verify right away!
Last edit: 6 years 10 months ago by Jasonpsapp17.
6 years 10 months ago #36128 by Cheryl
Replied by Cheryl on topic 2007 Silverado P0300
Try a crankshaft variation relearn? How does engine vacuum look? Should be able to see that on the map sensor pid should be nice and smooth no fluctuations. How many misfires are in history? Does it run bad currently
  • Jasonpsapp17
6 years 10 months ago #36130 by Jasonpsapp17
Replied by Jasonpsapp17 on topic 2007 Silverado P0300
Hey, I was hoping the relearn would do it but did not notice any change. Engine vacuum at idle was a fairly steady ahh 22 I believe. Should I throttle it as well? Didn't have a helper. I should have made a note of the reading but I it was right in the middle of a good spec so I called it okay.
It is running rough and missing on 3+8 mostly. Occasionally misses on a couple other cylinders but don't think those are as relevant.
Currently:
Cylinder 1: 1
Cylinder 3: 261
Cylinder 7: 6
Cylinder 8: 28
6 years 10 months ago #36131 by Cheryl
So the needle was steady?? Or fairly steady? Also got fuel trim numbers?
  • Jasonpsapp17
6 years 10 months ago #36135 by Jasonpsapp17
Cheryl, it was a steady 19 at the intake manifold I noticed though on tapping the throttle it dropped to 10 or so before it jumped to 30. Exhaust restrictions?
ST Trim-1(%) -1
ST Trim-2(%) 0
LT Trim-1(%) 9
LT Trim-2(%) 11
MAF 8.9 at idle??
6 years 10 months ago #36136 by Cheryl
Are you actually getting spark from cylinder 3 wire? Can it jump a gap in a spark tester. But one thing weird is you said ya have #1 injector flowing less fuel than the rest the firing order is 1-8-7-2-6-5-4-3 according to google. I’m wondering if the pcm is picking up the wrong cylinder misfiring since cylinder 1 is between 3 and 8 in the firing order. Maybe swap number 1 injector to cylinder 5 or something. Does the scanner perform a cylinder power balance test? To see if the misfire counter was right
  • Jasonpsapp17
6 years 10 months ago - 6 years 10 months ago #36139 by Jasonpsapp17
I will double check that spark tomorrow but I'm fairly confident I'm getting spark to 3.
I'll definitely look into swapping an injector at this point. The scan too does have the power balance test. So my understanding is I should notice the drop and if not, that is the dead cylinder? Static compression is good but tomorrow I'll get running compression as well.
I'm almost also ready to pop the valve cover and confirm it's not a stuck lifter
EDIT: I better mention this sooner rather than later. I assumed it to be part of the crank variation wot portion that set it off. P2119 may be related to a misfire or no? It's a TPS issue correct?
6 years 10 months ago #36146 by Cheryl
Just make sure you don’t have a stuck closed exhaust valve. It’ll have higher compression than the rest of the cylinders. Also I can’t remember if the number 3 cylinder is one of the cylinders afm controls.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
6 years 10 months ago #36153 by VegasJAK
Replied by VegasJAK on topic 2007 Silverado P0300
trims suggest a lean condition misfire as PCM is adding fuel. graph ST and LT fuel trims both banks on a fully warmed up engine and note the readings at idle again. Increase the RPM up to 2500 and note the trims as the RPM's increase. If they get better, you have a vacuum leak. By the misfire data, I think you have an intake manifold leak as you're getting a P0300 (random misfire) probably leaking more at the #3 intake runner.
downstream 02's report differently than upstream. they should be steady around the 700mv mark. B2S2 looks Ok... B1S2 should not be oscillating. that is the same side as piston #3. Fix the misfire first,
  • Jasonpsapp17
6 years 10 months ago #36159 by Jasonpsapp17
I have one more video coming with 02 sensor and engine data. This is the fuel trim video.
  • Jasonpsapp17
6 years 10 months ago #36165 by Jasonpsapp17
I swapped injector 1 and the misfires didn't change. Still mostly on cylinder 3.
Sprayed water all along the intake gasket and no change. Seems with the symptoms this is the problem but I've tried brake clean and water. The engine doesn't fluctuate with that.
Double checked spark is making it to cylinder 3.
Going to do a dynamic compression test
Any ideas??
  • VegasJAK
  • VegasJAK's Avatar
6 years 10 months ago #36173 by VegasJAK
Rough idle can be caused by a vacuum leak, EGR valve open or a problem with the PCV valve. You have/had the problem with the PCV valve. Recheck for leaks and that you are using the correct valve. Unplug the EGR and see if the idle clears up although if the valve is open due to carbon deposits on the pintle you may have to remove and clean. All these will cause a lean condition and misfire.
I have concerns with the B2S2 02. Its reporting 200mv. It should be up around 700mv. The lean condition along with the 02 can and will cause damage to your CAT. Test the 02 with propane and see if it responds.
Just wondering, Is the EGR on the #1 bank side?
  • Jasonpsapp17
6 years 10 months ago #36175 by Jasonpsapp17
It's my understanding this motor doesn't have an EGR valve. The PCV is internal to the valve cover. There was an updated cover due to the Active Fuel Management and oil consumption. Although this engine (220k) hasn't had significant oil consumption issues it seems there is a lot of oil/crud on the valve cover outlet where the pcv is housed.
How would I test the 02 with propane? Straight to the sensor with it removed?
I keep thinking and want it to be the common intake gasket leaking but I've checked with brake clean and water multiple times. No change in idle, still the same miss.
3 years 1 day ago - 3 years 1 day ago #63435 by Mwolt8211
Replied by Mwolt8211 on topic 2007 Silverado P0300
Did you ever solve this?  My Silverado is having the exact same issue just on the other cylinder bank. 2 and 6 are the ones acting up and I have tried same tests as you.
Last edit: 3 years 1 day ago by Mwolt8211.
